Reasonal $ Estimate For A Concrete Slab? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-03-2007, 04:10 PM   #1
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Question
Reasonal $ estimate for a concrete slab?
I am building a 24 by 16 foot storage building. Planning on a monolithic concrete slab 16 by 24 feet, minimum 4 inches, thickenened to 8 by 8 inches around the perimeter. Site is close to level with a max of 5 - 6 inch change over the 24 feet. Specifing wire mesh in the pour. Location is coastal South Carolina and frost is not an issue. I am located 10 miles from the redi-mix plant.($115.00 per yard delivered)
Contractor will add gravel to level site,compact, install forms, add wire mesh,install bolt down bolts, finish concrete (steel trowel) and remove forms.
Price quote is $1275. Is this reasonable for this job?
Old 12-03-2007, 04:37 PM   #2
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
where in SC? just wondering? That is a great price the concrete alone will be $ 690. I think he under bid , make sure you get it done right
Kingfisher is offline   Reply With Quote
Old 12-03-2007, 04:41 PM   #3
47_47's Avatar
Rewards Points: 44
A 24x 16 slab 4" thick will use 4 yards of concrete. Add for the curb. I personally would have the slab poured first, then the curb at a later date. If you plan on keeping heavy equipment (vehicle) in this storage building, I would go to 6". How about drain tile and a provision for underground power?
47_47 is offline   Reply With Quote
Old 12-04-2007, 10:44 AM   #4
Kingfisher's Avatar
Rewards Points: 150
Its not a curb , it is the footer around the slab , you have to pour it all at the same time . It's a little over 5 1/2 yards so you will need 6 that makes it $690.
Old 12-04-2007, 12:42 PM   #5
47_47's Avatar
Rewards Points: 44
Typed too fast. I knew the perimeter would be 8" deep to act as a footer, but I was already thinking to elevate the sill above grade level with a curb.
Old 12-04-2007, 08:11 PM   #6
robertcdf's Avatar
That is a hell of a deal. I would question if the guy is legit. Does he have a license? Does he have insurance? Does he have a bunch of illegals doing the work?
robertcdf is offline   Reply With Quote
Old 12-05-2007, 12:25 PM   #7
Boy that sounds right in line with my budget, I want a slightly longer building though.
Up here where I live, if you do some of the formworkand help with the pour, you can get some guys to do the finish side very cheap.
Sounds like a guy here where it's just him and his brother, they do small/medium projects just the two of them.
I have no experience, just stating what I've been told while shopping around to a couple guys.
OT: Kingfisher, you like old Ford's by any chance?
blthomas is offline   Reply With Quote
Old 12-05-2007, 02:01 PM   #8
Kingfisher's Avatar
Rewards Points: 150
Sorry, I'm a chevy boy But if you're giving a nice one away I change
Old 12-05-2007, 02:39 PM   #9
General Contractor
joasis's Avatar
That guy is working cheap....check references, or ask to see some of his work. This is like buying a $29,000 truck for $19,000.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 12-05-2007, 03:05 PM   #10
Oh OK. A guy on a Ford forum who was a huge help had the same screen name and was from FLA.
Sorry, trying like hell to keep mine.
Best of luck to the original poster, sorry for the hijack.
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
Remodel over sloped concrete slab PSL_Hokie Building & Construction 11 07-11-2007 06:14 PM
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 01:32 AM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
