Ready To Start Digging The Footers For My Deck. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-25-2012, 02:09 PM   #1
Rewards Points: 105
Ready to start digging the footers for my deck.
I am ready to string my mason's line as the centerline of my footers. My centerline needs to be parallel to my house 15 feet out. However, the dirt grade slopes away from the house and drops down about 2-3 feet. So, the question is how to ensure I am square with the house and exactly 15 feet out. The deck will be a second story deck.
I was thinking of using a PLS90 or PLS180. What do you guys use on grades that are not flat?
Bugman1400 is offline   Reply With Quote
Old 09-25-2012, 02:42 PM   #2
robertcdf's Avatar
Personally I'd build the deck on temp supports and then plumb bob down and then dig the holes.
robertcdf is offline   Reply With Quote
Old 09-25-2012, 03:17 PM   #3
Rewards Points: 1,772
Plumb bob and a can of spray paint to mark the ground should do it.
bob22 is offline   Reply With Quote
Old 09-25-2012, 08:14 PM   #4
Instead of using laser tools, I just setup taller batterboards at the lower side, strung some lines and measured.
Just make sure to:
1. take diagonal measurements to make sure they are the same;
2. each corner should measure 3'-4'-5' to make sure corners are 90 degrees
I don't know about your case, but my house was actually built slightly askew so by following the footprint of the house, my deck "encroached" on the property line by 4" so I had to get a waiver from my zoning dept.
So check with your building/zoning depts to make sure you are in the clear before pouring your footings.
Good luck
allthumbsdiy is offline   Reply With Quote
Old 09-25-2012, 08:20 PM   #5
Rewards Points: 14,312
But never use 1X's as batter boards, use 2 X 4's instead.
1 X 's will flex as you try to pull the string tight.
Old 09-25-2012, 08:27 PM   #6
Joe-
I agree with you except my house sits on top of bedrock near what used to be a copper mine
Whenever I dig, about 10% is dirt. Everything else is chunks of large rocks.
I even had to rent a Bobcat with an auger attachment to dig those holes or would have taken me couple of months to hand dig them.
So yes, use 2x4 if you actually have dirt
Old 09-25-2012, 09:41 PM   #7
Davejss's Avatar
Rewards Points: 782
That's how we've been doing it for years.
Davejss is offline   Reply With Quote
Miscellaneous deck questions NewHomeDIYGuy Building & Construction 38 09-17-2012 02:41 PM
Deck staining: percarbonate and power washing? WorBry Painting 15 08-31-2012 11:14 PM
leaking deck repair notacontractor Building & Construction 0 08-21-2012 11:34 AM
Backyard Project - Patio and a Deck OKDrew63 Building & Construction 16 07-16-2012 03:32 PM
Deck footers not 100% level? ssgumby Building & Construction 1 05-11-2005 07:32 PM
