Old 06-24-2012, 01:49 PM   #1
reading a survey
when the survey says "building cor. is 0.7'E " i assume this means about 9", and of course, the east side ?
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 06-24-2012, 02:58 PM   #2
Civil Engineer
reading a survey
cor, likely means corner
0.7' means 0.7 feet, which is 8.4 inches
E means east
Old 06-24-2012, 03:49 PM   #3
reading a survey
D.H. has explained the individual terms but, as a matter of interest, what is it that is 8.4" from the corner on the east side? Is the building leaning in that direction or something? Just curious.
tony.g is offline   Reply With Quote
Old 06-24-2012, 08:51 PM   #4
reading a survey
Without seeing the survey I can not be sure; but typically that notation appears where there is not enough room on the survey to insert a distance between the structure and the lot line. E.g. if the notation is for an accessory building that is near a lot line you know the corner of the shed is 7/10ths of a foot from the lot line. If this does not make sense then perhaps you can scan that portion of the survey and post it.
TheCamper is offline   Reply With Quote
Old 06-24-2012, 09:36 PM   #5
reading a survey
it is my neighbors house that is that close to my lot line
the 0.7 is the front of his house. survey says the rear of his house is 0.6
Old 06-24-2012, 11:54 PM   #6
GBrackins's Avatar
reading a survey
is your neighbor to the east of you?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 06-25-2012, 09:22 PM   #7
reading a survey
yep .............
Old 06-25-2012, 11:24 PM   #8
GBrackins's Avatar
reading a survey
then the front of his house would be 0.7' (measured perpendicular) from the lot line, and the rear is 0.6' (again measured perpendicular) from the lot line. at least at all the engineering/surveying companies I've worked for in the past 30 plus years that is what the numbers would mean.
Gary
Humidity Reading Jerry8C HVAC 11 11-11-2011 04:36 PM
VisionPro Outdoor Sensor Reading inaccurate bstone17901 HVAC 20 10-12-2011 07:59 AM
Reading glasses mwpiper Safety 24 09-06-2011 11:33 AM
Phantom voltage reading on switch loops jamiedolan Electrical 5 02-09-2009 05:22 PM
