Re-using Redwood Fencing - A Good Idea? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-08-2007, 09:06 PM   #1
Rewards Points: 31
re-using redwood fencing - a good idea?
I have some old redwood fence boards that are 9/16" thick. I'd like to re-use them in a new fence I'm building. They are very weathered (they're probably 25 years old) but sound. Are there any reasons not to do this? I'm putting in new pressure-treated 4x4 posts and new 2x6 redwood rails. I like the weathered look of the old boards and I like the idea of saving a tree. I plan to brush on a wood preservative, by the way.
Many thanks.
gulleyj is offline   Reply With Quote
Old 08-08-2007, 10:40 PM   #2
Agent 000
SecretSquirrel's Avatar
Hey, as long as the boards are in good shape, then go for it. You may want to consider a good presssure washing before putting them back into service. I only say that so the preservative treatment will not be adversely affected by any dirt or decay buildup. This may however take some of that "weathered" look away. Do a test piece and check it out. Another suggestion... after they dry out from the pressure washing, coat the boards with your wood preservative front and back and on the ends before nailing them up. If your new posts are evenly spaced and the boards are of consistant length then this little preparation thing will save you mucho time plus give you piece of mind knowing that you did your best to preserve the wood for another generation. Well... let me make a small disclaimer... clear preservatives are only good for a couple of years. Semi-transparent a few years longer and so on. This "preserving" does require maintenance. The good news is red wood is naturally decay resistant.
Dang it! Almost forgot... welcome to the forum!
SecretSquirrel is offline   Reply With Quote
Are they good Shenandoah Cabinets good quality? robertmazzo Carpentry 76 05-14-2015 10:23 PM
Flatscreen over the fireplace? Is this really a good idea? kashimama Home Theater 43 11-20-2011 12:01 AM
Laminate & hardwood in the same room, good or bad idea?? phatjoe Flooring 10 05-14-2011 10:57 PM
SLATWALL storage solution for Garage, Good Idea?... KUIPORNG General DIY Discussions 9 01-29-2008 10:15 PM
Question regarding soil makeup (will my soil amendment idea work?) joeyboy Landscaping & Lawn Care 5 06-30-2007 11:24 PM
