-   -   Re-siding 20 year old house.. (http://www.diychatroom.com/f19/re-siding-20-year-old-house-98279/)
casper129 03-13-2011 08:47 PM
Re-siding 20 year old house.. (With Pictures)
Hello all, I hope I am asking this in the right spot, as it's my first post and I'm not too familiar with this site. I tried doing a search on here, but I came up empty handed... Here is my question.
This spring I am going to reside my house. It is 18 years old, and currently has yellow vinyl siding on it. My wife and I don't like the color, so we are just going to replace it. I peeked under a piece of siding today, and there is pink insulation board under it. I don't know how thick it is yet. I'm assuming there is a vapor or moisture barrier (which one would it be?) underneath that pink board, and then OSB sheathing underneath that. My question is, when I take off the old siding, do I have to worry about all the nail holes from the old siding that are now in the pink insulation board, and the barrier behind that? If so, what would I do to correct this problem? Could I just use a house wrap over the pink board? Hopefully some of you can enlighten me and make our spring project a bit easier. I will be back tomorrow with some pictures of what I can see right now without any demo, and then I will be posting pictures and questions during my project. Hopefully some of you can help me out along the way :thumbsup:
Question 2 - Does the new siding have to be nailed to studs, or anywhere, since there is OSB sheathing on the house?
Thanks in advance!
BTW - I live in WI if that matters at all for house wraps and insulation and such....
Ron6519 03-13-2011 09:18 PM
The siding should be nailed into the studs.
I wouldn't worry about the holes, but I would remove some sections of the foam to inspect the condition of the sheathing.
Ron
casper129 03-13-2011 09:41 PM
Alright, the only thing that I'm concerned about is the rain water that gets behind the siding.. Some threads I read say that it needs to be sealed perfectly for the rainwater to travel down it.
And secondly, if the siding needs to be nailed to the stud, how am I supposed to find a stud when there's the pink insulation over the OSB, which is then over the stud...?
highcountrywnc 03-13-2011 10:16 PM
Stud Finder
Use a stud finder with a deep scan feature and you shouldn't have any problem finding the studs.:thumbsup:
casper129 03-14-2011 12:52 AM
^ Ok, sounds simple enough for me.
Another question, can I re-use my original starter strip after removing the present siding by just leaving it in place?
Ron6519 03-14-2011 07:29 AM
As long as it's not damaged.
Theoretically this siding was nailed into the studs. Use a marker to take note of the current nail locations and verify they're is studs.
Ron
casper129 03-14-2011 11:00 AM
Ok, now on to some trimming out questions. This past summer I had replacement windows installed. After looking at the trim around the windows yesterday, and what I've found on this website and online, I should have J channel all the way around the window. This picture shows the right side J channel around the window, with the (?) weeper holes (?)
http://i22.photobucket.com/albums/b3...e/IMG_0815.jpg
And this shows the bottom of the window. The builders of the house installed utility trim there.. So, should I use J channel when I put on new siding? Will J channel even work with that window?
http://i22.photobucket.com/albums/b3...e/IMG_0816.jpg
This is the top of the window. They just installed a drip cap here. I am lost as to what to do here. I think put J channel, and just cut the siding super thin to install it up there? Do I need to put drip cap back on there? How do I go about fixing this part.
http://i22.photobucket.com/albums/b3...e/IMG_0817.jpg
Here is my patio door (not yet replaced) This is how they did the top of the patio door.
http://i22.photobucket.com/albums/b3...e/IMG_0818.jpg
http://i22.photobucket.com/albums/b3...e/IMG_0819.jpg
http://i22.photobucket.com/albums/b3...e/IMG_0820.jpg
I'm assuming just take the utility trim out of there, and actually cut the siding to that size and install it above there right?
And do I need to replace these? If so, what are they even called? (Vinyl over foundation)
http://i22.photobucket.com/albums/b3...e/IMG_0821.jpg
Thanks again for the great help guys.
casper129 03-14-2011 10:47 PM
Also, does drip cap get caulked anywhere? And from the pictures, it looks like it's just shoved up under the J channel for the soffit.. is that correct?
