Old 12-03-2006, 05:27 PM   #1
yummy mummy's Avatar
re-routing central vacuum pipe
I have a central vacuum pipe protruding from the ceiling inbetween joists, in my basement.
It extends approx. 12 inches down right in the middle of the room.
Can I re-route this pvc pipe? (I think it's pvc, some kind of hard plastic and it's approximately 2 inches in diameter).
Presently I do not have central vacuum, but when we built the house I put the rough in for it.
I wanted to re-route it to what eventually will be the furnace room.
Can I cut it and put in an elbow piece and add a straight piece and run it over to where I want it?
Also, how to I attach pvc pipes together? (Glue???????)
yummy mummy is offline   Reply With Quote
Old 12-03-2006, 05:29 PM   #2
World famous jerk.
Central vac pipe installs the same way pvc plumbing pipe does. It is thinwall, though. The material is available at your electrical supply house.
mdshunk is offline   Reply With Quote
Old 12-03-2006, 05:30 PM   #3
What is "thinwall"
re-routing central vac pipe-how to attach elbow piece yummy mummy Building & Construction 3 12-02-2008 12:58 PM
Determining drain pipe routing? tigerbalm2424 Plumbing 3 03-09-2007 09:12 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
