Re: old buildings
Here, you can get a building permit for $5, I added a new studio room on my house in 2006 and all they required was a rough sketch of the property the room plan, and $5
You certainly could do most of the grunt work yourself, and even if they are stringent, you can do the work and have a licensed pro go over it and check it for a fee, just keep to the code or better, and get every book you can on the particular systems so you can learn the correct practices, techniques,tools to use, materials to use etc and you can't wrong.
This is why roofs are so important to keep maintained, the smallest leak can cause big trouble.
The floor in my kitchen- the kitchen was originally a back porch resting on foot square 8 foot long logs that looked like they were once massive supports salvaged from a commercial building, they were laid directly on some flat rocks on the ground and their centers and bottom were basically all rot.
The floor had a 6" tilt to it across the width, the other end of the joists rested on a 2x4 simply nailed to the concrete block foundation wall.
I wound up digging the whole area out, putting in footings, drainage, block walls up, and replacing all the joists with new because the old ones were salvaged junk, some were nothing more than 2x6 and some were 3x12 and every other odd size you can think of, and they had splits and rot.
With as many windows as there are there, and the cost for heat these days, and the fact the brick has an almost zero R value, every bit you can do will be a massive help on heating and cooling costs. There are modern replacement windows that look appropriate and have dual pane argon low E glass, and not cost too much.
I replaced all the windows on my 1930 house and it made a huge difference I could measure. My kitchen is where my desk is, it has 3 large windows- about 5' square for the largest (2 double hung set side by side) with the original windows here, in the winter I would actually get ICE on the glass inside, and the glass itself was so cold it set up a convection current that felt like a draft.
I HAD to have a 1500 watt space heater in the room on me all the time because it was so cold.Once I replaced those 3 windows, the first winter I found I didn't need that space heater AT ALL, I found my electric bill dropped by about $35 a month. That winter I saved enough on the electric to cover the cost for one of the windows! I no longer feel a cold draft, ice does not form on the inside of the glass any more.
They don't have stock windows that fit my openings for height, they were close though and I was able to fit them in well.
This is a vinyl window on my new studio room addition, I trimmed around them (replaced all the old ones) with the same style as the original windows, as you can see, it all looks appropriate to the style of the 1930 house, I even sided the room with new clapboard I made sized the same as the originals. As a bonus the window comes in white, and white trim is what I always used on the house, so it was perfect.
The side boards, header and sill are all treated lumber, most of the originals on the house had bad rot. These windows were about $135 each, double glass, argon, low E and with a screen included, I love them!
That is the reality, you can be historic to a "tee" but things like windows will cost you a lot of money for heat/ ac, and lack of comfort.
The rest of my house has R100 attic insulation and R25 in the walls and it's comfortable.
I had added more insulation to the walls by adding a second wall inside as the plaster and lath were in poor condition, on the interior of all exterior walls I screwed 2x2 strips to the wall studs with long screws, filled that 2" space with celotex, a vapor sheet over that,1/2" plywood and 1/2" sheetrock. I used ply in there so I can hang heavy things on the wall and not have to bother finding studs for anchors.
There is at least one contractor I know of who does plaster/lath walls, but this is largely a lost art and it's very expensive and a lot of hand labor involved. You would certainly have to replace with standard sheetrock, but even with this, there's opportunities to give it a texture with sheetrock mud, trowels, stiff brush etc so it's no so flat and smooth.
I used a wallpaper paste brush and sheetrock mud to texture with- moving the brush in rows of semi-circular fan patterns like the old ceiling had in many places.
That's another issue, the attachment to neighboring buildings when one has a leaking roof and is in major deterioration. The plaster damage, celing caving in etc is indicative of a lot of water getting in the walls from the roof, and it's mostly trapped in there.mt999999 said:
As long as the foundation and brick walls are solid, in plumb and in good condition it's certainly saveable. The big killer besides cost, is if the leaking rain from the roof soaks into the top and upper brick walls and starts freezing, then you have major trouble!mt999999 said:
I have a feeling all of those will need more than work, closer to replacement with in-code materials and practices. I don't know how stringent your buildings dept is there, but here the city said no permits were needed for renovation/remodelling as long as it's not a structural change, or a change in use i.e. taking the commercially zoned building and making it a residence.mt999999 said:
I have a nasty feeling that won't be allowed, besides, the original rafters and floor joists are typically inserted into a pocket in the brick walls at each end, likely the wood in those pockets is rotted and piggy-backing a new board alongside the old will still rely 100% on the integrity of the old wood in the pockets. You can bet the roof deck is rotted where the leaks are.mt999999 said:
I disagree with that guy, IF the building is a historic designated landmark, or it had unusual curved glass windows, stained glass, bevelled glass, was built by George Washington etc then the originals should be saved, but for the most part those old wood windows were simply purchased off the shelf from a supplier, the old version of Menards in a way. Those drafty loose windows were put in back in the day when coal was $5 a ton or less and they didn't care how much heat went out.mt999999 said:
If you need to gut the exterior wall plaster/lath to the brick, I would certainly use that opportunity to put insulation in there! It would save a lot of money in heat/ac.mt999999 said:
