Re-locate Or Remove Post In Basement - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-27-2011, 05:00 PM   #16
Civil Engineer
Rewards Points: 4,692
No doubt you have the software, but do you have the skill and training to use the software correctly? An old professor of mine once told me that the time to take out the software was when you already had a good idea what the answer was. None of the calculations are rocket science, but the details can be killer.
Old 02-28-2011, 10:45 AM   #17
Concrete & Masonry
Rewards Points: 548
Originally Posted by Millertyme View Post
do all you post look like the one in the picture? That is a telepost. It looks like someone was trying to lift that beam. Those teleposts are meant to be taken out after the lift is done and replaced with lally columns.
Not sure haw you can tell it's a temp. post from that picture, but it sure doesn't look like one to me. Don't let the screw adjuster fool you, it isn't an automatic indicator of a temp. post. As a matter of fact, every permanent post we use here looks similar to the fraction of the post in the picture, we just generally flip the post the other way so the screw jack is locked into the concrete floor.
jomama45 is offline   Reply With Quote
Old 02-28-2011, 10:52 AM   #18
Experienced
Jackofall1's Avatar
Couldn't agree with you more, software in knowledgable hands is a tool, in hands that are not, it is a accident waiting to happen.
Mark
Old 03-01-2011, 04:38 AM   #19
Yes it is a permenant post, the other (Floor end) is set in the concrete, as you mentioned
jerrylee is offline   Reply With Quote
Old 03-01-2011, 04:48 AM   #20
Mark
I agree even more, it took me many years to actually trust the numbers,
Over insulate basement? braverichard Building & Construction 26 06-22-2010 08:26 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
6x6 Cedar post rot stanltod Carpentry 2 06-21-2009 04:54 PM
basement post removal rb76 Building & Construction 6 06-13-2009 09:43 AM
