Re-leveling Floor From Settled Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-19-2012, 01:31 PM   #1
DIYer
Rewards Points: 93
Re-leveling floor from settled foundation
Hi all
I purchased a cheap fixer recently that has a 50ft concrete foundation wall that has settled over time and has brought the floor visibly out of level. It is a load bearing exterior foundation wall with joists running perpendicular.
I've priced out foundation replacement and it's not in the budget unfortunately. The most cost effective option would be keeping the foundation wall but jacking up that one side of the house then putting in longer studs. There is a 6.5' basement so there is lots of good access and room to work
In my head this sounds feasible for an experienced DIYer but I'm curious what you guys think. Recommendations on powerful house jacks would be appreciated as well
dwoloz is offline   Reply With Quote
Old 03-19-2012, 02:08 PM   #2
Rewards Points: 626
Hire a company like these people http://www.robbinsfoundationsystems.com/
I am sure there is company like theirs in your area. or they can direct you to a company that can help you out.
Nailbags is offline   Reply With Quote
Old 03-19-2012, 02:11 PM   #3
Rewards Points: 1,092
"...that one side of the house then putting in longer studs." And why is it not feasible to "fill the gap" somehow between the foundation and house? Once you get the wood up, couldn't one frame in temporary form boards and pour in concrete, or is that what you are using the "longer studs" for; a short, tapered wall? Maybe I'm just not seeing things; happens all the time. And as Nail said, this may be a proper time to hire someone w/ the equipment and (hopefully) knowledge to get the house up, then you do the fill in part.
Old 03-19-2012, 03:54 PM   #4
Civil Engineer
Rewards Points: 4,522
If you replace the short studs with longer studs, but keep the foundation wall the way it is, what guarantee is there that the wall will not continue settling, and you will have the same problem again in a few years?
Old 03-19-2012, 04:20 PM   #5
DIYer
Rewards Points: 93
I could fill the gap with new concrete actually. Might be easier (even though I'm not much for concrete). How I was thinking, the sill plate would be removed then reapplied.
Of course, there is zero guarantee to anything that any of us knuckleheads do. However, this house is 90 years old and has had neglected drainage issues. My guess is that its done the settling its going to do and if the drainage issues are addressed, additional settling is unlikely
Old 03-19-2012, 04:46 PM   #6
90 yrs old? Yes, probably settled what it will, as it will be gone "shortly" (surely less than another 90 yrs), esp if you address drainage. A cheap, fairly durable fix sounds in order.
Leveling skids for a shed on a unlevel concrete foundation will02 Building & Construction 7 01-16-2012 03:58 PM
Stone Foundation 'Temporary' Repair... Peter B. Building & Construction 17 12-16-2010 01:27 PM
Round House Foundation Feasibility Mswick Building & Construction 23 02-27-2010 09:34 AM
Foundation Has Settled 1/4 inch Need to Relevel Noticed Something Odd cloves Flooring 8 11-04-2009 06:20 AM
Foundation Repair Help rasilun Remodeling 1 10-15-2009 11:26 PM
