Re Grade Outside - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-11-2011, 11:48 AM   #1
Re Grade Outside
Greetings all, this spring I want to regrade the ground around my house to divert water away from the foundation...my question(s) is. How deep should I dig? and what type of "fill" works best... and please let me know if I am forgetting anything... Next question. I live in an area with a lot of springs...after heavy rains I get water that migrates through the floor, any ideas to stop this without a french drain? Thanks!!!
Denzo is offline   Reply With Quote
Old 01-11-2011, 11:56 AM   #2
Stay-at-home GC
If it were my place I would bring in a mini-excavator and dig down to the footer. If your going to regrade and seed anyway.
Depending on your situation you could lose the extra dirt in the regrading.
This will allow you to:
1. Inspect the footer for a drain and install if necessary
2. Install a water resistant treatment to the outside of the foundation
3. Backfill with washed gravel
4. Add a ground gutter if desired
5. Install rain conductors
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 01-11-2011, 11:59 AM   #3
BIGRED
Rewards Points: 252
Do you have a slab floor, a crawl space, or a basement? Do you have flower beds around the house or just lawn? Is your home on the side of a hill or in a depression? Do the springs run all the time or just certain times of the year? I need moooore information.
Grampa Bud is offline   Reply With Quote
Old 01-11-2011, 12:07 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,736
Ayuh,... You don't necessarily need to Dig,...
You just need to create pitch Away from the house...
In my case, it just meant filling in along the side of the house with top dirt, 'n seeding it...
Depending on the lay of the land, 'n the height of the structure, you may need to dig a swale, or Not...
The Following User Says Thank You to Bondo For This Useful Post:
Denzo (01-11-2011)
insulate (mostly) above grade concrete wall britepepper Building & Construction 7 06-19-2010 07:39 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Outdoor outlets jamiedolan Electrical 1 01-17-2009 11:15 AM
Below grade fireplace venting BillL HVAC 7 01-15-2008 07:20 PM
