Re: Glue Together 1" Sheets Of Extruded Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-07-2009, 11:57 AM   #1
Rewards Points: 150
re: glue together 1" sheets of extruded insulation
does anyone know what is the most appropriate glue for gluing together two sheets of extruded polystyrene insulation?
-thanks
gramps416 is offline   Reply With Quote
Old 01-07-2009, 11:58 AM   #2
-thanks
LePage PL300
Reilley is offline   Reply With Quote
Old 01-07-2009, 02:06 PM   #3
I have used the spray foam in the past.
Worked great for me.
I have actually seen GC use it to glue 2"-4" blue foam to the ceiling of a house and then run 6" screws through it later.
I have actually witnessed them walk on the foam with no screws & only the foam used as the adhesive. Scared me, but they did it.
N
natemclain is offline   Reply With Quote
Old 01-07-2009, 02:15 PM   #4
Sure you could use spray foam, but PL300 is under $3 a tube and spray foam is considerably more expensive. There are other adhesives on the market that are suitable for foam, just check their labelling.
Old 01-07-2009, 02:56 PM   #5
Great info!
Sounds like it is much cheaper.
Old 01-07-2009, 04:17 PM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Spray adhesive: http://solutions.3m.com/wps/portal/3...beSC2785KN7Pgl
Others: http://solutions.3m.com/wps/portal/3...beSC2785KN7Pgl
- Build Well -
Old 01-07-2009, 07:08 PM   #7
Rewards Points: 150
I just got some PL300 from the HD.
On the tube, the product stated that it is specifically made for gluing the ridgid insulation together. $3.50 CAD for a small tube
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Old home insulation woes nowwhatnapster Building & Construction 15 11-03-2008 12:59 AM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 03:13 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
