-   -   re: glue together 1" sheets of extruded insulation (http://www.diychatroom.com/f19/re-glue-together-1-sheets-extruded-insulation-35344/)
gramps416 01-07-2009 11:57 AM
does anyone know what is the most appropriate glue for gluing together two sheets of extruded polystyrene insulation?
-thanks
Reilley 01-07-2009 11:58 AM
-thanks
LePage PL300
natemclain 01-07-2009 02:06 PM
I have used the spray foam in the past.
Worked great for me.
I have actually seen GC use it to glue 2"-4" blue foam to the ceiling of a house and then run 6" screws through it later.
I have actually witnessed them walk on the foam with no screws & only the foam used as the adhesive. Scared me, but they did it.
N
Reilley 01-07-2009 02:15 PM
Sure you could use spray foam, but PL300 is under $3 a tube and spray foam is considerably more expensive. There are other adhesives on the market that are suitable for foam, just check their labelling.
natemclain 01-07-2009 02:56 PM
Great info!
Sounds like it is much cheaper.
AtlanticWBConst. 01-07-2009 04:17 PM
Spray adhesive: http://solutions.3m.com/wps/portal/3...beSC2785KN7Pgl
Others: http://solutions.3m.com/wps/portal/3...beSC2785KN7Pgl
gramps416 01-07-2009 07:08 PM
I just got some PL300 from the HD.
On the tube, the product stated that it is specifically made for gluing the ridgid insulation together. $3.50 CAD for a small tube
