Old 06-06-2009, 12:40 PM   #1
Re-Facing Fireplace Wall with Veneer
Hi. I am thinking about putting a stone or brick veneer over the finished drywall around my current fireplace. The fireplace itself was added after our home was built, it is ventless and the wall encasing is completely hollow....besides studs. The wall encasing the fireplace pretrudes out from the side wall about 2 feet. See pictures attached.
I have not decided if I am going to replace the current mantle or just keep the existing one. I have my LCD mounted and I ran all wires behind the TV, up through the attic and into our media closet. I'm not too concerned right now if I have to leave a small area of exposed wall behind the TV that is not veneered, as it will be out of sight.
Does anyone have experience with a project like this...veneering over drywall? Should I just use a galvanized mesh lathe and morter scratch coat, should I use a vapor barrier, where should I look for veneer stone, can you cut it and what do you use,etc?
Any information is extremely appreciated!
Thanks.
Matt
bamatide is offline   Reply With Quote
Old 06-06-2009, 04:14 PM   #2
Each manufacturer will have guidelines. Pick the stone you like and follow the instructions.
Prior to purchase, check out to see if your situation is compatible with theirs without major restructuring on your part.
Ron
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Possible to build direct-vent fireplace? DIYerself General Discussion 3 12-22-2007 11:07 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 04:49 PM
