Old 12-13-2011, 02:40 PM   #1
re enforce garage to build loft
Hope someone can help me with this.
I have a very high garage roof but 3/4 of the way up the roof trusses start.
I think they are called Finch trusses made out of 2x4 and they have a w type re enforcemt to the bottom of the Joist.
I would like to remove the w Pattern and re enforce the top with 2x6 and frame the walls in 2x6 they are 2x4 now with a brick veneer.. once that is all done I would build the loft.
Does anyone know if this is possible or do I have to remove the whole roof and truss?
Fsitlts is offline   Reply With Quote
Old 12-13-2011, 02:57 PM   #2
Disabled wood vet
titanoman's Avatar
Never cut any truss for any reason.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-13-2011, 02:58 PM   #3
You would need to have the truss evaluated for modification or replacement by the manufacturer.
Ron
B. Franklin 1759
Old 12-13-2011, 03:05 PM   #4
maybe I explained it wrong really what I wanna do is convert into a cathedral ceiling.
Old 12-13-2011, 03:08 PM   #5
Disabled wood vet
titanoman's Avatar
Then...to start off with, you will need at least 2x10 rafters...
The Following User Says Thank You to titanoman For This Useful Post:
Fsitlts (12-13-2011)
Old 12-13-2011, 03:10 PM   #6
what I am worried about is do I have to re enforce the walls too to take the extra weight ?
Old 12-13-2011, 03:12 PM   #7
You should have an engineer look at it.
Those trusses don't just hold up the roof, they keep the walls from spreading out.
Evstarr is offline   Reply With Quote
The Following User Says Thank You to Evstarr For This Useful Post:
Old 12-13-2011, 03:21 PM   #8
The advice is the same. You can't just modify the trusses without knowing how, without possible dire consequences.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
Old 12-13-2011, 03:39 PM   #9
There is only one person qualified to tell you if you can modify your truss in any way, and that is the engineer at the truss manufacturer.
Look them up online and give a call -- the answer is probably a simple "no."
To do what you want, you probably need to tear off your roof and re-frame it.
pyper is offline   Reply With Quote
Old 12-13-2011, 05:28 PM   #10
Just a DIY guy
good advice.
Engineered trusses are just that: "engineered." They are built so that they use the least amount of wood but are still strong enough to hold up the roof and transmit all the load to the exterior walls (typically). Plus they hold the tops of the walls in place. They do this by breaking up the framing into a series of triangles, which transmit loads in different directions. When they are connected these triangles form a unitary structure. Cutting any truss without a full recalculation of the loads and stresses involved is asking for truss failure.
Given that you want to build a loft, with associated live and dead loads, you may have to reinforce the walls as well, to take the extra loads.
Your best bet is to hire a structural engineer. But be prepared for him to tell you that it's going to be very expensive to do what you want to accomplish. As pyper said, you may have to remove the roof to reframe the whole thing.
M3 Pete is offline   Reply With Quote
What is best way to build a detached 24x24' Garage with a Basement underneath? eastpamt1 General Discussion 10 12-07-2011 01:10 PM
Cathedral insulation in garage loft - at an impass! JarekBialik Roofing 9 09-29-2010 12:26 PM
Garage Insulation DIYguy2000 Building & Construction 2 12-09-2009 08:41 AM
how to build an open garage? weedfan Building & Construction 12 05-05-2009 01:53 AM
