RC1 / Drywall Orientation? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-25-2010, 12:44 PM   #1
Reading a ton on Resilient Channel, etc...
Question, can you run the long sides of the drywall parallel with the channel? Or does it have to run perpendicular?
Curious, because I have a really LONG and skinny room, and would love to run my sheetrock the long way - I would have a lot less cuts, waste, and tapping.
However, if I did the RC1, and I had to switch the direction of the drywall, that's a pain.
So, does it matter which direction RC is installed on drywall?
Thanks.
Sammyc53 is offline   Reply With Quote
Old 10-25-2010, 05:45 PM   #2
Registered User
Rewards Points: 5,514
Orientation depends on drywall thickness and if a water based texture will be applied, read the footnotes, Table #1:
http://www.gypsum.org/pdf/GA-216-07.pdf
Gary
Old 10-25-2010, 06:35 PM   #3
Thanks, handy link In accordance to that, I can go parallel or perpendicular as I will have 5/8" on 16" Centers with no spray on stuff.
However, I'm curious as to if this will negate the benefits of using RC1 channels? From what I've read, it's easy to make this stuff useless if not used correctly.
Old 10-25-2010, 10:16 PM   #4
Registered User
Someone else may know.... I'm not much into sound control since my 4 boys are now men.....
Gary
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Drywall panel orientation question tpagel Drywall & Plaster 6 11-25-2009 10:44 AM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
