Rat Runs In Attic - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-11-2012, 01:42 AM   #1
Rat Runs in Attic
Can I Remove The Rat Runs In My Attic To Install A Plywood Floor?
thechalker is offline   Reply With Quote
Old 12-11-2012, 02:59 AM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 664
Send a message via Skype™ to AndyGump
I think the more common term for "rat run" is Strong back. I suppose you can do whatever you want to with your ceiling but I think the first question you should ask is 'is the ceiling built or designed for a floor for living space or storage.
If living space the joists should be designed for the type of loading that you intend for up there. Is it a bedroom that will need 30# live loading or other living space that requires 40# live loading?
Light storage for about 10# live loading, etc.
Will there be a permanent stairway access or just a pull down staircase?
There are many things to be considered before just jumping in and tacking plywood for a "floor".
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 12-11-2012, 09:27 AM   #3
Rewards Points: 13,300
Also if you plan to use this area for storage and keep it unheated by adding plywood your going to be cutting way down on the avalible area for proper inshttp://www.energystar.gov/index.cfm?c=home_sealing.hm_improvement_insulation _tableulation.
Old 12-11-2012, 08:36 PM   #4
Strong Back
Andy and Joe,
Thanks for the responses. I have checked with my Truss manufacturer and although the space is not designed for living, they say I can load up to 25 lbs psf in the attic with the trusses installed. I plan to add 1/2" plywood and 2x4 supports between each truss bottom cord at 2 foot intervals. The weight for this I will add will equal about 3.0 psf. Then I plan on storing my wifes christmas and other holiday decorations, suitcases, cat cages, etc. I also will install a pull down stair.
What do you think can I remove the Strong Back that was nailed in the center of the space?
Old 12-11-2012, 09:24 PM   #5
kwikfishron's Avatar
Rewards Points: 224
A “strong back” and a “rat run” are two different things where I come from.
A strong back consist of two 2x’s nailed in a L shape to stiffen up ceiling joist. A rat run is a single 2X nailed flat on top of the bottom cored of the trusses and have no other purpose other than keeping the bottom of the trusses on layout. You nail the rat run on layout prier to nailing the bottom cord of the trusses to the top of interior walls.
If what you have is a rat run (cat walk) then it could be removed imo. Whether or not your trusses can support storage weight is another story.
kwikfishron is online now   Reply With Quote
Old 12-11-2012, 09:35 PM   #6
Rat Run in Attic
kwikfishron
Thanks a lot - what I have is a rat run and I appreciate the help.
Old 12-12-2012, 08:59 PM   #7
Registered User
Rewards Points: 5,266
Some call a single a "ribband" and a double, a "strongback" as Andy said,; pp. 372; http://books.google.com/books?id=cFW...eiling&f=false
Older trusses have little bracing, may/not have Step 7: https://docs.google.com/viewer?a=v&q...OI5rmXQVBl6Wfw
Gary
(Partial) Radiant Barrier Above Finished Attic? Lascaux Insulation 11 09-26-2012 08:56 PM
an attic fan AS a whole house fan? JLAMBERTI HVAC 2 06-21-2012 02:04 AM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 05:17 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 11:50 PM
Attic Fan Runs Slow kcarrier Electrical 19 07-28-2009 09:57 PM
