-   -   range hood venting (http://www.diychatroom.com/f19/range-hood-venting-58942/)
interested 12-10-2009 07:33 AM
range hood venting
curious as to correct way to insulate and terimnate range hood vent through roof?
Bob Mariani 12-10-2009 08:00 AM
Wrap insulation blanket around the duct work in the attic space after taping all seams with metal duct tape. Use a covered roof vent cap on the 6" duct exiting the roof. Use a roof boot on the roof.
interested 12-10-2009 08:02 AM
do they make ones that don't allow backdraft?
Bob Mariani 12-10-2009 08:10 AM
use an inline damper for this, not the roof cap. The cap should have an insect screen also.
Michael Thomas 12-10-2009 10:09 AM
Damper required in range exhaust hood
Yup, a damper required by M1502.1: "Range hoods shall discharge to the outdoors through a single-wall duct. The duct serving the hood shall have a smooth interior surface, shall be air tight and shall be equipped with a backdraft damper...."
Gary in WA 12-10-2009 11:37 AM
I would insulate with more than the R-7 required by some codes. The idea is to stop condensation and grease from depositing on the pipe insides. You want the pipe as warm as possible. I would use a roof cap damper w. screen rather than an in-line damper that lets cold air in the rest of the pipe when the unit is not being used. The attic temperature will help temper the pipe a little more, to stop condensation if the pipe was warmer than the outside air. And..... Welcome to the forum!
Be safe, Gary
