Ramset For Metal Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-08-2008, 11:05 PM   #1
Ramset for metal framing
Has anyone used a ramset to attach a track to the concrete when framing with metal/steel.
thanks
Mirimaggy is offline   Reply With Quote
Old 10-08-2008, 11:11 PM   #2
Registered User
Termite's Avatar
Yup.
Old 10-09-2008, 06:33 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Yes, use a low power charge (cap) with a short "treated" fastener. You only need a 1" or less length fastener. You can also use a cap type fastener as well.
- Build Well -
Old 10-10-2008, 01:16 PM   #4
Drywall contractor
Rewards Points: 1,070
Agreed........be sure you have the right pins and use eye/hearing protection.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 10-10-2008, 06:30 PM   #5
Idiot Emeritus
Rewards Points: 1,492
You can shoot wood down to concrete as well, just use a longer pin.
In fact, using the proper pin, you can even shoot stuff like electrical boxes onto steel.
Rob
micromind is offline   Reply With Quote
Old 10-14-2008, 10:19 AM   #6
Chagres's Avatar
I shot down miles of track and also up for clips for acoustical ceiling hanger wire over a 14 year career, so the answer is yes! The loads come in different strengths, with yellow being the most common. But if your concrete is old (really, really cured), it will tend to chip out when you shoot it. If this happens, back off to a tamer load, probably brown.
If you're not going to be using it much, save money by buying one that is activated by whacking it with a hammer, rather than one that uses a trigger.
Chagres
http://www.icanfixupmyhome.com
Chagres is offline   Reply With Quote
framing material estimate maydoug Building & Construction 38 06-12-2009 01:32 PM
How do I find a framing contractor in Rhode Island christy123 Building & Construction 2 10-25-2006 10:29 PM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 09:27 PM
Wood Framing Getting Wet? stagger19 Carpentry 2 05-10-2006 08:37 AM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
