Old 07-06-2007, 11:34 AM   #1
Ramifications of Using an Incorrect Mortar Mix
We believe that our contractor may have used 100% portland cement to set our clay patio bricks instead of the cement/sand/lime or cement/sand mixtures as recommended pretty much everywhere I've looked. What are the likely ramifications of using 100% cement?
Thank you.
makke is offline   Reply With Quote
Old 07-06-2007, 02:43 PM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
I have heard of this but have no experience. How does it look? How does it feel under foot? What is the base under the bricks? Are they really clay bricks or are they pavers?
Brik is offline   Reply With Quote
Old 07-06-2007, 04:02 PM   #3
"How does it look?"
It looks fine to my untrained eye.
"How does it feel under foot?"
Feels solid, they are set in mortar, after all.
"What is the base?"
A concrete slab on top of gravel.
"Are they really clay bricks?"
Yes, they are really clay bricks. We chose them specifically because we don't like the artificial look of paver systems.
Old 07-08-2007, 09:54 AM   #4
Agent 000
SecretSquirrel's Avatar
I would expect 100% Portland to be very brittle and to separate from the pavers over time due to expansion and contraction from temperature fluctuations.
Is there some doubt as to what he REALLY used? Why don't you call him and ask him directly?
SecretSquirrel is offline   Reply With Quote
Old 07-08-2007, 05:38 PM   #5
concretemasonry's Avatar
Where did you get the rumor? Were there any bags of materials left around after he left?
Just ask what he used.
It would be much more expensive and troublesome to use Portland cement and water without sand or lime if he could even work with the mixture.
Have you considered that he may have used a pre-proportioned mix that was bagged?
concretemasonry is online now   Reply With Quote
Old 07-08-2007, 06:24 PM   #6
Portland cement mixed with water is unworkable and would be cracked and dusty within a day or two.
Tscarborough is offline   Reply With Quote
Old 07-08-2007, 07:07 PM   #7
Thank you for the comments. We are not sure exactly what was used because at the time we thought they knew what they were doing and, as a result, we did not pay a lot of attention. When the patio dried, however, all of the bricks were discolored. So, we started doing our own research.
Turns out that they installed the bricks like tile, with grout placed into the gaps and wiped with a damp sponge. The discoloration is from the mortar being smeared around and absorbed by the porous bricks. The proper technique is to butter two sides, place the brick, and wipe away access with a trowel. The tile technique is also likely to leave voids within the mortar that will initiate cracks due to freeze/thaw cycles.
Anyway, to make the long story short, once we figured out that they used a totally incorrect technique, it became obvious that they did not know what they were doing. Therefore, we started questioning other things. I remember seeing bags that said "Portland Cement" and I don't recall seeing them mixing in any sand. However, it is certainly possible that the bags were indeed a proper pre-bagged mix.
The contractor is on vacation for two weeks. We will ask him when he gets back. However, before we did that, we wanted to understand the possible consequences. Your comments are very helpful -- thank you.
Old 07-08-2007, 07:34 PM   #8
Actually, the proper method is to set the brick into a mortar bed, then use a grout bag to fill the joints. You do not grout it like tile.
Bad Brick Mortar ??? kourso Building & Construction 21 11-08-2010 01:11 AM
Backerboard not in mortar -- How bad is that? House_Amuck Flooring 28 09-27-2010 11:33 PM
Is it bad to use mortar to level a floor? CB2007 Flooring 4 10-01-2008 09:38 AM
Is Structalite up for Tub-setting (instead of mortar?) House_Amuck Plumbing 2 03-20-2007 07:09 PM
can I reuse mortar bed ? mf915 Flooring 1 07-04-2006 08:14 PM
