Raising Roof - Need Some Info - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-25-2010, 02:50 AM   #1
Rewards Points: 14
raising roof - need some info
Hello,
I have an 1820sq ft single story craftsman style house with crawl space / perimeter foundation built in 1974. The house is in San Mateo, CA.
Assuming that the foundation can support it, 1) can someone give me a ballpark estimate of just raising the roof by 5 ft and putting up the exterior walls?
Also, 2) what kind of contractor(s) do I need to contact to do this and 3) how long will such a project typically take?
Once the roof is raised and exterior walls are setup, I plan to do rest of the interior, electrical, plumping, heating, etc work later on as budget permits.
Thanks,
Albert
albertpinto is offline   Reply With Quote
Old 10-25-2010, 08:14 AM   #2
Civil Engineer
Rewards Points: 4,962
I am not in the estimating business, for that you would need to ask for an estimate from one or more qualified contractors. A framing contractor or homebuilder would be a good place to start. I am curious why you are raising the walls five feet, that isn't enough for a second story, but is more than I would expect simply to raise the ceiling height.
Daniel Holzman is online now   Reply With Quote
Old 10-25-2010, 04:40 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,736
Ayuh,... It's usually cheaper 'n easier to just rip off the roof, then stud up to height, 'n build a New roof....
Old 10-29-2010, 01:23 AM   #4
Rewards Points: 14
I figure increasing the height by 5ft will be sufficient to add around 1000sq ft of fully permitted loft style space that could be put to multi-purpose use: games area, study area, etc.
Ya thats what I figured. once the exterior walls and roof are up, I could take care of the rest as time and money permits. Still looking for some kind of cost estimate for doing this in san francisco bay area.
Old 10-29-2010, 06:33 AM   #5
DIY staff
Rewards Points: 7,174
About the only way to get a ball park figure,will be to visit a local architect with photos and measurements--Local architects usually have a handle on local building costs---
EPDM Roof Plans stubits Roofing/Siding 44 04-30-2010 11:06 PM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 10:02 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
Tile+Asphalt Roll Roof leaking - Opinion on what to do brookbphx Roofing/Siding 5 01-06-2009 06:51 AM
Addition and Roof Replacement lebeld Roofing/Siding 4 01-04-2009 06:11 PM
