#1 |
Raising overhead joists in my garage. Is this a good idea?
Hi all. In my garage, the over head joists are really low. They are 2"x12"x20' and there are approximately 6 of them. The walls of my garage are standard 2x4 frames spaced 16" apart. The ends of the joists are nailed to the vertical 2x4s on the left and right walls. There is also approximately a 16" gap between the joists and the tops of the walls. What I'd like to do is remove each joist, one at a time, and raise them so they are flush with the top of the walls. Each joist is connected to a vertical 2x4 on the walls with 2 normal framing nails on each end. So what I'm thinking of doing is starting with the first joist, knock it out at each wall, raise it up flush with the top, nail it back in and then do the 2nd, 3rd, etc. If I do this one at a time, is this safe to do? Check out my attached picture and let me know what you think. Thanks!
#2 |
General Contractor
JP,
I haven't come across your "as is" lay out. Ceiling ties/joists typically sit on the top plate and flush to the rafters. Maybe someone wanted that space for added storage? I don't know/see a reason not to proceed, but you might consider some beefier hardware. 2 framing nails seems a little underwhelming to carry a 20' member that typically sits on a plate. Maybe some bolts? Good luck!
Rory To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Portland, OR |
#3 |
definitly more fasteners
The older I get the better I was |
#4 |
Moderator
The bolts are only as good as the nails into the top of the studs through the plate. Could you post a picture?
Be safe, Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
#5 |
Hi you guys. Thanks for your replies. I know what you mean about the joists sitting on top of the plates, but in my case, they don't. I think it's because of the way the roof was constructed. It's an X frame pattern where there is one primary peak, in the middle. I took a picture of one of joists where it attaches to the framing. You can see the gap between the joist and the top plate of the wall frame. I want to move it up, but after looking at it, I'm not sure if I even need them at all. If I take them down completely, will my walls cave in? See attached pic. Thanks!
JP |
#6 |
Xtreme DIY'r
Do not take them down
You do need rafter ties between the walls to keep them from spreading out This occurs slowly over time Does that 2x under the rafter extend all the way to the bottom 2x plate ? If so that is pretty good support Do you have a wide pic of all the framing ? |
#7 |
Moderator
With a 20’ total span, the rafter ties (2x12’s) need 6 nails each side for a 4/12 roof and a 30# snow load. That is nailing into the heel of the rafter or using a Simpson connector instead. The ties should be next to the rafters, not down the wall any. A 5/12 roof needs 5 nails each side. http://www.engineersedge.com/civil_e...onnections.htm
The 2x4 rafters are over-spanned if D/F and no snow load = 8’11” span max. I would move them up and nail them to the rafters where they belong. They sure look to be 2x10’s….. Be safe, Gary
#8 | |
Raising overhead joists in my garage. Is this a good idea?Quote:
I looked at the simpson ties, but I'm not sure which ones to use. Can you send me a link of which one's I should use? Also, it is 20' across, the joists are 20' long, but I have a support mechanism in the middle that I'd like to take out (see attached pic). If they're 2x10s or 2x12s and are 20' long, they won't sag if I take out the middle support system will they? Thanks! |
#9 | |
#10 |
Demolition Mode
I hope you dont think im high jacking your thread, but can I ask what software progrram you used to draw the picture in your beginning post. I am a very visual person and would like to make similer drawings of my projects. Thanks... Happy Remodeling
Handy Dave |
#11 | |
JP |
#12 |
General Contractor
Scuba Dave noticed that you have jack studs under the ties. To me, that is a reasonable alternative to seating it on top of the plate.
If you move the ties, you should have longer jacks. In typical wall construction, a jack should run continuously from the member it is supporting all the way down to the bottom plate. If you don't want to rip those existing jacks out and choose to place a short piece on top, you should sister a new stud that runs plate to plate creating a sandwich for the ceiling tie. Use a lot of nails. I wouldn't worry about the bolts with that construction. I personally would not rebuild the entire rafter system unless it was starting to fail. I would not take out the center bearing wall if I was storing much of anything on top of the ties. Cheers,
| The Following User Says Thank You to Rory Read For This Useful Post: | drtbk4ever (06-06-2012) |
#13 | |
JP |
#14 |
General Contractor
JP,
I don't think you can put the ties on the plates now. The rafter size and pitch is going to require too much of the rafter to be cut away. It's the width of the wood sitting on the plate that counts, so, if there is only 6" left after that cut, it doesn't matter that it's 2x12 in the middle. It's all bearing on the portion that's a 2x6, and that's too small for the span. If you play around with the span calculator at http://www.awc.org/calculators/span/...rcalcstyle.asp, you will see that a 2x12 can handle that span as a ceiling joist with only minimal loads on top. You use that overhead space at your risk. Joist to rafter framing will help support the roof. It is not intended to strengthen the load bearing capacity of the joists. I think you would need beams under the joists if you want to remove the center wall and use the joists for storage.
#15 |
Xtreme DIY'r
I would either raise them up so that the top of the joists hits the bottom of the top plates
OR Possibly notch the beams & install them around the top plate? Then install a new support stud underneath (crude drawing) Seems like a lot of work for very little gain But I know having headroom makes an area seem much bigger Thoughts?
| Display Modes | |
| Flatscreen over the fireplace? Is this really a good idea? | kashimama | Home Theater | 43 | 11-20-2011 12:01 AM |
| Garage Attic Floor Joists | zacmac | Carpentry | 3 | 11-02-2009 10:07 PM |
| SLATWALL storage solution for Garage, Good Idea?... | KUIPORNG | General Discussion | 9 | 01-29-2008 10:15 PM |
| painting my garage floor (and some outdoor slabs) - are these any good? | joeyboy | Flooring | 2 | 10-17-2007 09:13 PM |
| re-using redwood fencing - a good idea? | gulleyj | Building & Construction | 1 | 08-08-2007 10:40 PM |
