RAISING A FLAT ROOF TO A SLOPED ROOF + Heat+great Room Reno - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-25-2014, 08:09 AM   #1
RAISING A FLAT ROOF TO A SLOPED ROOF + Heat+great room reno
We have a 120 year old home that had several additions over time. One has a flat roof that has now started accumulating ice water and leaking. We have long wanted to slope it down and are ready. At the same time we had a radiator pipe in the crawl space below burst in the same room while out of power after a ice storm and have no heat there at the same time. Plus we have no insulation so we need to open the walls for that too. Did not want to do it this year but here we go!
The room is 14x17 and is at the south west corner of the house and we are planning to add 2 skylights as well as open the back wall to windows and sliding doors as well we need heat! It is a step down from a 14X17 kitchen that I would like the same floors in...preferably not tile. There is a crawl space under but it is inaccessible unless we rip out the flooring. But we need to so that we can insulate. I would like 2 sources of heat- just in case one has trouble later...easier to run wiring now. Also I dont want tile in my adjacent kitchen....any thoughts on sloping roofs, heating sources that are not forced air,insulating crawl spaces, skylights, or any thing else you think may help?
Ilovemyhouse? is offline   Reply With Quote
Old 01-25-2014, 09:01 AM   #2
PoleCat's Avatar
Rewards Points: 1,638
Pictures and or drawings will get the juices flowing.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
roofermann (01-25-2014)
Old 01-25-2014, 09:46 AM   #3
roofermann's Avatar
Rewards Points: 399
The only skylights I would use on my own house are Velux with the flashing kit.
roofermann is offline   Reply With Quote
Tags
heating , insulation , roof , skylights , supporting beam
extend roof over flat roof nate1582 Roofing/Siding 16 05-21-2012 12:35 PM
Best way to replace/insulate a flat tar-gravel roof Hexar Roofing/Siding 19 10-08-2010 01:17 AM
install trek on flat roof of another room to creat deck? ckurita Building & Construction 11 05-23-2009 10:29 AM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 03:51 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
