Raising An Enclosed Garage Floor...? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-03-2013, 09:50 AM   #1
Question
Raising an enclosed garage floor...?
So we are under contract on a fixer upper and it is currently a one bedroom one bath house...(they expanded kitchen into the former bedroom). They also enclosed the garage into a second living space, but it is a two step down into it. The ceiling is the same height as the rest of the house so we were thinking that if there was as way to raise the height of the floor to the height of the rest of the house, It would seem less like an enclosed garage, making a great bedroom. I have some familiarity with deck building. Could you use the same concept and just build a raised floor using joists tied to the studs, or, a ledger board attached to the studs then joist hangers...? Never heard of this being done so thought I'd ask. Also, what would you do with the space below? Add a vent to the outside to match the crawlspace in the rest of the house? Seems like it would work to me, but y'all may be able to explain why it is a dumb idea. Home is in southern Oklahoma if that matters. Thanks in advance!
-Huggins90
Huggins90 is offline   Reply With Quote
Old 01-03-2013, 10:08 AM   #2
Haverhill Trade 1965
Using a ledger or attaching to studs creates balloon framing. you should fire block between studs to stop fire from spreading to walls. Best ledger is to notch studs about an inch and recess the ledger for more strength. You would then use joist hangers. I might even rip 1" from one set of blocks behind ledger and another row above the floor level, where the shoe would normally be. Depending on the span you might build a small knee wall under the center to reduce bounce too.
Duckweather is offline   Reply With Quote
Old 01-03-2013, 10:10 AM   #3
Rewards Points: 13,300
It's done all the time.
One issue may be that the floor is sloped toward the old garage doors.
Got some pictures inside and out?
I'd like to see how they covered up the area where the old garage door was.
Done wrong and there can be water leaking in under the wall or rotting sheathing because it's so low it's to close to the old aprin.
Duckweather (01-03-2013)
Old 01-03-2013, 10:40 AM   #4
Rewards Points: 730
After some thoughtful planning, I might just take a different approach even though the original structure has a wood floor. I might just call a ready mix truck and be done with it pronto.
Old 01-03-2013, 10:50 AM   #5
GBrackins's Avatar
Rewards Points: 2,108
we do this all the time. typically we'll install a center beam with new footings. we install fireblocking between the studs at the floor level, install ledger boards to the face of the studs and attach floor joists to the ledger boards using hangers and lap over the center beam. We typically use cmu block to "block in" the overhead garage door openings to same height as top of foundation. units are secured with rebar set into the foundation.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
jomama45 (01-03-2013)
Old 01-03-2013, 10:51 AM   #6
And what are they going to do?
How many inches is it from your house floor to the garage floor now? Two steps should be about 14". That's a whole lot of concrete.
Old 01-03-2013, 10:58 AM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
As JoeC said, too much concrete to be practical. A wood floor is a much better idea. Provides space for electrical, plumbing, heating/AC ducts and insulation.
Install vapor barrier over the old concrete floor.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 01-03-2013, 11:01 AM   #8
Engineered floor joist would make far more sence then concrete.
Tags
enclosed garage , joist span , raised floor , subfloor
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 07:42 PM
Settlement under Garage Floor taadz Building & Construction 10 08-30-2012 09:58 PM
3" gap between concrete driveway and garage floor need to fill frankrizzo Building & Construction 0 11-23-2010 09:08 AM
3" gap between concrete driveway and concrete garage floor - help! frankrizzo Flooring 0 11-23-2010 09:07 AM
Subpanel - detached garage without a floor SAS Electrical 12 03-05-2009 12:42 PM
