Raising Ceiling (rafters) In Detached Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-19-2010, 03:27 PM   #1
Rewards Points: 29
Raising ceiling (joists) in detached garage
Hey guys.....
First post here
I am buying a house next week that has a detached once car garage, 20 X 14. The garage was built with the house in 1938. Of course the roof is not trussed, just built in place. The bottom of the rafters is pretty low, probably 8 feet and thats being generous. Can I cut the joists (I might be calling them something wrong) and move them up a foot or two and then resize and reattach to the roof rafters. This would give a lot more headroom in there.
I'd also like to make the garage bigger down the road by expanding it out to 20X20 and replacing the whole roof rafters and all with a porch off the side. I realize this would probably require trussing to accomplish.
I have attached a simple diagram that shows what I'd like to do. Blue is the current position, green shows how I'd like. I know the higher they go the less effective they will become.
acme54321 is offline   Reply With Quote
Old 05-19-2010, 04:28 PM   #2
Stairguy
Millertyme's Avatar
Rewards Points: 508
The joists don't seem to really be needed except to keep the walls tied together while the rafters were installed. I would say you really dont need them, as you wouldn't have them there if you had a cathedral ceiling. If you are just going to move them up it might be fine.I am no expert on framing nor am I an engineer, This is only my opinion based on what i know
Millertyme is offline   Reply With Quote
Old 05-19-2010, 04:40 PM   #3
Incorrect
The ceiling joists keep the walls from spreading out
They are needed after the rafters are built & roof installed
You can move them up, depending upon rafter size, snow load etc
I think they still need to be installed in the bottom 1/3 of the rafter length
In a cathedral ceiling the ridge bean is a BEAM properly sized that supports the roof
In most instances theree is only a ridge BOARD installed, not sized to hold the weight of the roof
Old 05-19-2010, 04:52 PM   #4
Rewards Points: 29
Thanks guys, I'm actually a Mech E, just enough knowledge about structures to get me in trouble I just want to check with people about building knowledge. I know they are only there to keep the walls from bowing out. I may just raise them but leave a couple in down low for piece of mind, not really sure.
What I am more worried about are my later plans of expansion and how I can do the roof. This thing is really simple contruction and I was hoping that I could just expand on it somehow.... not sure about a 20 ft span though as far as the joists go.
Turns out that statics class actually has become slightly useful!
Old 05-19-2010, 05:22 PM   #5
If the plan is to extend the garage I'd just leave them until you redo the roof
Are you going to have 2 garage doors?
Are you taking the existing wall on the left down ?
You are better going off with ane equal angle roof over the whole thing
Rather then the 2nd lower slope you show in your diagram
Old 05-19-2010, 08:01 PM   #6
Rewards Points: 29
Steve,
You mention a ridge beam for a cathedral ceiling....
Is that essintially where the ends of the roof are trusses with a full legth beam across? Then the end trusses and beam position the roof and the rafters maintain the tie in with the walls?
Old 05-19-2010, 08:07 PM   #7
A Ridge Beam runs the full length of the ridge & is SIZED to carry the roof load
For a 20' run it would not be one board
It would be LVL or something similar
For a ~23' distance my ridge beam was sized as (3) 16" LVL's
The rafters do not tie in the wall
The beam supports the weight which prevents the walls from pushing out
Old 05-19-2010, 08:14 PM   #8
Rewards Points: 29
Ah, got it. So what do the rafters tie to on the bottom end if not the wall?
Old 05-19-2010, 08:25 PM   #9
The rafters attach to the walls top & bottom
But they do not (fully) tie walls together
Weight presses down, without the rafter ties to tie the walls togethe rteh walls will eventually bow out
How fast depends upon rafter size, span distance, snow load, weight of roof....etc
Old 05-19-2010, 08:39 PM   #10
The rafters lay on the wall and are nailed in place to prevent the roof from lifting off from wind!
In my area we have to consider, not only the pressure exerted outwards on the walls, from the weight of the roof. But, also the snow load.
Our snow fall exerts 30 p.s.f. so our collar ties cannot be raised as high they could be in the south.
We think of the joists that run from the tops of the walls as collar ties and if they are raised, as rafter ties.
Other regions may refer to them differently!
Old 05-19-2010, 09:21 PM   #11
Registered User
Rewards Points: 5,514
Dave, "You are better going off with ane equal angle roof over the whole thing
Rather then the 2nd lower slope you show in your diagram" ------- I believe that his plan is a 20' wide garage with the 8' ? porch roof attached in a truss. (The low sloped roof in his diagram).
"The beam supports the weight which prevents the walls from pushing out" ------- the ridge beam supports 1/2 the roof weight with the walls supporting the other 1/2 divided at the walls.
"For a 20' run it would not be one board
It would be LVL or something similar" ----- It could easily be a 6x12, D.F., Select #1, which would safely carry his load in FL. (no snow load). Many types of engineered lumber beams are able to replace solid lumber beams, but one of many could handle it. (and greener)
"The rafters do not tie in the wall
The beam supports the weight which prevents the walls from pushing out " --------- The rafters tie the walls to the ridge for shear flow against racking and seismic loads down to the ground. Ridge blocking and positive rafter fastening required per local code.
OP, " So what do the rafters tie to on the bottom end if not the wall? " ------ The walls.
Check with your local Building Department for FL hurricane tie downs before you build to warrant your Homeowners Insurance liability.
Be safe, Gary
Old 05-20-2010, 06:15 AM   #12
Rewards Points: 29
Well, the expansion won't come for a little while, and it shoudln't be much work to move them. Currently it has one small door, which is a two piece barn door style. I'd like to replace it eventually with a normal overhead door, but I will probably leave it one car size. This garage will never be a "garage." Just a workshop/man space/W&D area. One thing I am not sure of is how the washer and dryer are plumbed, I'll have to look at that. I am pretty sure it isn't through the slab though so that is a plus.
The 2nd roof is just a porch roof. The neighbors have something similar on their little garage and they have a grill under it and whatnot, looks nice.
Old 05-20-2010, 06:22 AM   #13
Rewards Points: 29
Be safe, Gary
Gary,
I had this concern also. The garage is fairly shielded though from the wind. There are treelines right up against it to the east and north and the house to the south. I will deffinately look into what is required though as far as wind issues when I come to that point. I do figure though that just mimicing what has been there for 70 years will probably be ok, it is still standing rightside up after a few storms
Old 05-20-2010, 10:42 PM   #14
Registered User
70+ years ago the building codes were quite different. I currently have remodeled house that I framed 35 years ago and things have changed a lot. It is all for your safety, and code is the bare minimum. Visit your County's web site for your local conditional changes from the IRC.
Be safe, Gary
Old 05-21-2010, 06:57 AM   #15
Old School
Willie T's Avatar
CLICK HERE for a calculator that will give you a fair (though not totally exact) estimate of the forces your rafters apply to your side walls.
Willie T
Detached Garage: Design Question esemrick Building & Construction 4 01-12-2010 04:59 PM
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing/Siding 3 11-06-2009 09:07 AM
garage roof insulation between rafters denverman71 Building & Construction 1 10-21-2009 12:06 PM
Detached garage setup - Switch loop setup jamiedolan Electrical 3 02-07-2009 12:08 PM
Grounding for new meter at detached garage steve37887 Electrical 1 10-22-2008 02:17 PM
