Raising The Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-09-2010, 11:16 PM   #1
Raising the ceiling
I have a 20 by 40 foot building that I want to raise the ceiling on. The building is on a concrete foundation and inside with the trusses the ceiling is only 6'5". I was thinking if I cut the the rafters and moved them up on the truss itself this would be the cheapest way to raise the ceiling. Is this idea sound or am I making the roof weak?
farmerken is offline   Reply With Quote
Old 02-09-2010, 11:41 PM   #2
jlhaslip's Avatar
Rewards Points: 2,816
truss system or rafters would be dealt with differently.
do you have rafters or trusses?
cutting trusses is not a good idea.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 02-09-2010, 11:45 PM   #3
I guess I'm using the wrong terminology
By truss I mean the piece that runs straight across from wall to wall. By rafters I mean the piece that runs from roof peak to the wall
Old 02-09-2010, 11:50 PM   #4
SO let me try again
I want to cut the cross piece (run straight from wall to wall) and move the piece up about 17" and reattach to the piece that runs from roof peak to the wall
Old 02-10-2010, 01:02 AM   #5
jlhaslip's Avatar
The flat piece that runs from wall to wall is a ceiling joist. It acts to stop the roof from forcing the walls to be pushed outward.
Moving them from the top of the wall to a position 17 inches up will reduce their effectiveness, but it is physically possible to move them upwards.
Having said that, you would need to likely have an inspection done for your location by a qualified engineer or building inspector to confirm that it would be acceptable by them in your region.
Lots of time (around here) where the inspections are only done 'in town', lots of things get done out of town, but the long term results are that "stuff happens" that are not planned for. In your case, I would expect that there would be consequences. The walls might start to lean or separate from the roof, causing some grief. Just saying...
Old 02-10-2010, 07:40 AM   #6
makes sense
I was afraid that something like that might happen. I understand that the joists are there to tie the walls laterally to the roof. So any ideas on the best way to raise the ceiling? I can try to post some pics in the next day or two.
I guess I would have to raise the whole roof.
By the way. Thanks for all the advice and help. It really helps me having a place to discuss ideas before things start to come apart. You know the old quote ( It sounded like a good idea at the time)
Old 02-10-2010, 11:55 AM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,638
Ayuh,... I'd set up some jacks,+ blocking inside, under the ceiling joists, right next to the walls,...
Then disconnect the building's anchors from the slab,...
Jack it up as high as you'd like, then throw up a tier or 2 of blocks, a knee wall, or whatever to extend the walls downward to the slab...
Old 02-10-2010, 01:05 PM   #8
Post a picture of the rafters/joists/truss
There is a huge difference between stick (joist & rafter) built & truss system
You can't just cut a truss system apart
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
Raising the ceiling MrTique Building & Construction 4 12-04-2007 10:06 AM
raising ceiling height, raftered at 8 and 10 already DoubleD07 Building & Construction 13 07-20-2007 07:05 PM
raising ceiling height during remodel marks Building & Construction 1 10-04-2006 01:58 PM
