Raised Paver Patio - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-09-2011, 10:06 PM   #1
Raised Paver Patio
So here is my current patio. As you can imagine this holds all the waterwhen it rains. I would like to bring it up to the level of the yard which is about 6 more inches and angle it away from the house. What would be the best way to go about this? I would like to use pavers again but nicer than the bricks you see here. Can i leave the current bricks in there? what would be best to use to raise it up, gravel and then sand? Any help would be great thanks! Id like to try this myself if I had some more info.
yocoop is offline   Reply With Quote
Old 06-10-2011, 07:41 AM   #2
Rewards Points: 5,336
If you raise the level of the ground anymore, you'll bury the siding in dirt because you'll be over the level of the foundation.
As it is, the level is too high against the house.
If the area floods, install an underground drainage system to catch the water and direct it away.
Another option would be to install a perimeter retaining wall with an associated perimeter drain to a drywell.
Ron
B. Franklin 1759
Old 06-10-2011, 08:59 AM   #3
Ok thanks, so my best bet is to dig it all up... Maybe make it even deeper and install drainage system. I feel like that's better than raising it. Appreciate it!
Old 06-10-2011, 01:33 PM   #4
Depending on the yard slopes, you might be able to just build one retaining wall and lower the other 2 side so the patio drains naturally.
Ron
B. Franklin 1759
12-18" Spacing Between Foundation And Paver Patio Bad Idea? ErikU19 Landscaping & Lawn Care 3 04-09-2011 08:20 AM
DIY Paver patio and retaining wall Huey2003 Landscaping & Lawn Care 1 02-07-2011 12:11 PM
Paver patio for raised foundation house? sandyman720 Landscaping & Lawn Care 1 05-06-2010 05:06 PM
Paver Patio question Hoopscoach Landscaping & Lawn Care 1 04-25-2010 03:55 PM
new deck or paver patio meth Landscaping & Lawn Care 7 06-06-2008 05:20 PM
