Raised Foundation Drainage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-21-2011, 04:59 PM   #1
Question
Raised foundation drainage
Our house is on a raised foundation and has drainage problems which is causing our new hardwood flooring to "cup" in several locations. What would be the long-term fix for this problem. A French drain?
dstrate is offline   Reply With Quote
Old 04-21-2011, 05:21 PM   #2
Rewards Points: 5,326
I'm a little confused by the post. How does a house on a raised foundation(one above gorund level) have issues with water?
Is the floor in the basement?
Is the ground graded properly? That would be away from the house.
Are the leaders extended away from the house?
Ron
raised slab foundation tclark Building & Construction 6 01-07-2011 09:10 AM
Foundation Drainage bhry Building & Construction 3 09-23-2010 11:08 AM
moist soil under raised foundation during winter bn300 Building & Construction 0 09-17-2010 03:51 AM
foundation drainage lee12 Building & Construction 0 06-28-2010 10:40 AM
Advice on Retrofit Water Drainage For Foundation 4 FT Under cloves Building & Construction 13 04-07-2010 11:47 PM
