Raised Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-02-2011, 07:45 PM   #1
Raised Foundation
Hi all,
I would like some input on my idea to save some money on a house by eliminating the basement and build on only the pilings and beams to form the foundation system.
I figure 12" concrete pilings every 8 feet used with beams of 2x10's tripled, glued and screwed.
Does that sound reasonable?
wwsteel7 is offline   Reply With Quote
Old 04-02-2011, 08:09 PM   #2
Originally Posted by wwsteel7 View Post
Hi all,
Depends on where you live. Putting in a basement is the most cost effective way of making space.
Here in Canada, 99% of homes are built with basements for this very reason.
If you live on a ranch in southern Texas, then having a basement is not so compelling.
My friend built an addition onto his house using piers and spent a large amount of money closing it in and had no extra space to show for it!
Old 04-02-2011, 08:48 PM   #3
Rewards Points: 1,016
Many houses are built without basements - moreso depending on where you live. I grew up in Indiana where basements were common. I have lived most of my adult life in southern states, where basements are uncommon. Water table issues (when I lived in New Orleans for example) can make doing a basement difficult. Rocky ground can also be a factor.
Pilings and/or a perimeter foundation wall, creating a crawl space is one way to go. A monolithic concrete slab is popular in many areas (here in SoCal for example). You have to take into consideration how deep you have to go to get under the frost line. Sometimes a basement is difficult due to rocky ground. Another option is to consider a partial rather than a full basement.
As was mentioned, a basement can be relatively inexpensive space. It can provide a good place for mechanicals to be installed, living space, utility room, etc.
raised slab foundation tclark Building & Construction 6 01-07-2011 08:10 AM
poured foundation wall with infill for raised paver installation 3- 4 feet high mgraniello Building & Construction 1 09-26-2010 09:06 AM
moist soil under raised foundation during winter bn300 Building & Construction 0 09-17-2010 02:51 AM
Paver patio for raised foundation house? sandyman720 Landscaping & Lawn Care 1 05-06-2010 05:06 PM
Foundation Repair Help rasilun Remodeling 1 10-15-2009 10:26 PM
