Raised Cornice For Rafters - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-26-2013, 04:30 PM   #1
Rewards Points: 274
raised cornice for rafters
I am in the process of designing a detached garage with apt loft above. Rafters to rest on top of raised cornice (3- 2"x6"'s) on top of ceiling joist for a little extra height because I need all the extra room I can get. My first question is: is this ok, shouldn't go any higher w/ the raised cornice right? The only other option I can think of to get more room without making entire structure wider is to use 10' studs on first floor but have a 9' ceiling w/ jacks supporting joists. Also with first example of using the raised cornice, when drawing living space upstairs (12:12 pitch) I am measuring 1' rise to 1' run measuring from outside wall across floor and from floor to rafters. I figure the 3-2x6's will offset the amount I am losing for rafter notch cut, finished floor and ceiling. Hope all this is making sense and thanks for any help, I can provide more detail if needed.
ugabulldog is offline   Reply With Quote
Old 01-26-2013, 04:43 PM   #2
Rewards Points: 12,830
Why not a gambrel style roof? Or even a hip? A whole lot more room would be avalible.
Old 01-26-2013, 05:01 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
You lost me on the hip having more room, there would be less room in a hip attic than a gable attic.
Roll Tide, sorry, couldn't help myself there.LOL
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 01-26-2013, 05:30 PM   #4
Rewards Points: 274
I dont like the look of gambrel roof on garage.
Old 01-27-2013, 10:03 AM   #5
AHH, SPANS!!!
Rewards Points: 1,166
another way is to frame a knee wall onto the top plate that goes 6 to 12" above the top of the joists. build walls, set the joists, and then frame the knee wall right next to each joist with a double top plate on the knee wall and then frame the rafters. this could be better than laying down 3 flat 2x's
hand drive is offline   Reply With Quote
Old 01-27-2013, 11:55 AM   #6
Rewards Points: 274
actually, after more thought, I think i would rather widen structure rather than have cornice work sit too high from ground, top of windows/doors, also it will have a lean to porch and dont want that raised up to high also... so is 3-2x6 too much of a raised cornice, structurally speaking?
How do I manage a flange that is raised above the floor? CZ DIY Plumbing 7 09-10-2012 11:46 PM
Wicking Baskets for raised boxes gobug Gardening Forum 0 08-12-2012 02:27 PM
what does 'under raised building' mean? hunter6516 Building & Construction 8 10-26-2011 07:44 AM
raised slab foundation tclark Building & Construction 6 01-07-2011 09:10 AM
raised garden on septic tank Rae Landscaping & Lawn Care 4 04-27-2010 11:27 AM
