Rainscreen Siding Detail - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-08-2012, 05:13 PM   #1
Rewards Points: 59
I am going to be replacing cedar siding with new cedar siding with a rainscreen. I plan on using 3/8" or 1/2" PT plywood strips or maybe a plastic type product from Cor-a-vent
I will be installing some new wood windows (without any flange), but also keeping some of the old ones. The window casing will be flat 5.5" wide (cedar or maybe Miratec).
My questions is how to detail the rainscreen at the windows? One idea was to flash the window as usual, and then use thicker casing (2x instead of 5/4) directly over the flashing/building paper. I think it would be better to have the rainscreen behind the casing as well, but I am not sure how to close off the gap between the window and the casing (1/2"). I could add 1/2" extension jambs to the windows, but I bet those would rot out pretty quick.
Thanks in advance for any ideas.
handyman923 is offline   Reply With Quote
Old 03-08-2012, 10:18 PM   #2
Rewards Points: 1,092
buildingscience.com and/or greenbuildingadvisor.com should have details for you.
Old 03-09-2012, 06:52 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
i do this type of detail quite often. first install your furring strips around teh window openings, install a vycor or blueskin drip pan on the sil first.. then set the window into a bead of caulking at the sides and top of the opening..now install a metal cap flashing over the brick mould and have the top flange of the flashing tuck up under the tyvek.. do this for all your windows.. fill in all the vertical furring strips on the walls nailing into studs so to make sure they dont come loose
best practice now is to run a bead of clear caulking behind each peice of siding where it buts into the windows and doors to seal the joint.. leaving the notch in the siding over the window un-caulked so any water that does get behind the siding can run back out . once the siding is completed face caulk all the siding at windows and doors. also skipping the caulking over tops of windows and doors
woodworkbykirk is online now   Reply With Quote
Gap between siding and sheathing & foundation? Wiscbldr Building & Construction 2 08-18-2011 06:56 AM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
