Rain Water Going Under The House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-01-2011, 04:30 PM   #1
Rain Water going under the house
Hello. I saw in many places inside the house, a lot of moisture. The dry wall ( about 3 feet high) was very moist. Because, I checked it was not
a plumbing problem, the conclusion was that it was a rain problem.
The water managed to go under foundation and cause the moisture to the
drywall. The carpet was dry maybe because the floor is concrete.
How do I repair the problem ?
A. I put concrete all around the house sloping away from the house.
B. Take the drywall out and put aluminum sheeting 3 feet high ( the kind
we put in the valley of the roof ).
The song says: It never rains in Southern California, but this time it really
rained a lot. Any Advice ? Must the foundation be so bad that water is
sipping through ? I appreciate any suggestions. Thank You.
Gabriel24 is offline   Reply With Quote
Old 01-01-2011, 05:00 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,062
Ayuh,... It ain't gotta be Concrete, but Yes, the grade should slope Away from the foundation for 10' or 15'....
Bondo is online now   Reply With Quote
Old 01-01-2011, 10:35 PM   #3
If I do not put concrete sloping away from the house, then what am I going to put so the water does not filter through ?
Steam heating system in an old house. Do I add water, and where? Salvatorparadise HVAC 2 12-24-2010 05:51 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Water pooling next to house foundation pictures - help suggestions Steelmesh Building & Construction 8 07-03-2009 10:05 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
