Rain Screen Construction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-09-2011, 08:05 PM   #1
rain screen construction
I am adding an exterior wall 90* into my existing exterior wall. This will make a right angle of two walls 30" long x 8' high and 12' long x 8' high. On top of the 1/2" plywood sheathing I will place 30# felt. I want to construct a rain screen between the felt and the exterior finish. I want to place 3" strips of ventilated plastic strips on the studs over the felt. I have a product called "Craft Foil", it's a radiant barrier product. The instructions advise for best use to create an air gap between the barrier and the wall. I wanted to place this product on top of the plastic ventilation strips. Question is will I be creating two barriers which will create moisture? Or should I just install the Craft Foil product on top of the plywood sheathing and just forget the felt?
Second question is I'm trying to find a product like vinyl or fiberglass that is a smooth one or two piece system to install as my finish wall. Would like something different then vinyl siding. Thanks.
bileaux is offline   Reply With Quote
Old 08-10-2011, 08:40 AM   #2
AGWhitehouse's Avatar
Sounds overly involved and I'm not quite sure what you're even describing...
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 08-10-2011, 09:53 AM   #3
That craft foil was mainly used as a vapor barrier on concrete block construction. Of course times have changed. Now its put on the interior side of the block to give a little extra "R" factor.
Master of Cold is offline   Reply With Quote
In-swing non-crank casement window screen blee Windows and Doors 2 05-21-2011 02:42 PM
Soft Hearted Construction Guys Wildie Building & Construction 0 11-29-2010 06:05 PM
Any ideas about how to build a temporary construction screen? benjamincall General DIY Discussions 11 07-26-2010 08:49 PM
Rain screen Icefishww General DIY Discussions 5 03-19-2009 10:57 AM
Rain Gardens Colchicine Green Home Improvement 2 02-13-2009 06:35 AM
