Railroad Ties- What Are The Downsides? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-28-2008, 12:25 PM   #1
deuce of all trades
Railroad ties- what are the downsides?
Greetings, All...
A wood lot near me has a big stack of railroad ties for cheap. Far, far cheaper than equivalent lumber. This has me thinking.
Aside from the fact that you'll get dirty if you rub against them, what would the problem be with using them as uprights for a detatched carport?
Given the price advantage I would expect to see them used more in outdoor construction, but it's very rare to see them. Is it the smell? Code violation? Weaker than they look? Fire?
Cheers,
...dave
lanispet is offline   Reply With Quote
Old 03-28-2008, 01:28 PM   #2
Rewards Points: 1,220
Somewhat toxic (even more-so when you start cutting on them), hard to work with, and, by the time they are for sale to the public they often have rotten spots.
Tscarborough is offline   Reply With Quote
Old 03-28-2008, 08:02 PM   #3
Custom Cabinet Maker
Also most rr ties are creosote treated which could be considered hazardous waste material. Dont do it
skymaster is offline   Reply With Quote
Old 03-28-2008, 09:10 PM   #4
remodeling pro
Originally Posted by lanispet View Post
Greetings, All...
Fire?
..dave
If you use them in a spot such as you suggested, you will get more than "dirty" when you rub against them. Creosote , while a great preservative, is pretty nasty stuff. It will permanently stain anything it gets on, and is highly irritating to skin, resulting in spots on you that look like you have literally been burned or scalded. And the smell never goes away from the product. They are best left alone, not only for these reasons, but at stated, they are availabe to you because they have been removed from service by the RR due to their deteriorating condition, thus the anticipated life span of them is less than you expect.
And just as a kicker, creosote is highly flammable.
troubleseeker is offline   Reply With Quote
Old 03-31-2008, 03:12 PM   #5
deuce of all trades
Thanks for the info... I knew creosote wasn't very nice, but i didn't think it was quite that bad. i also thought that while it had a lot of energy, it took a lot of heat to ignite (substantially higher temp than untreated pine). I'd planned to get around the staining issue by sheeting them in either PTL planks or vinyl siding to match the house. Ah well.
Thanks,
...dave
Trusses, collar ties and knee walls Ricki Lee Building & Construction 1 03-20-2008 09:29 AM
collar ties explained? troycalm Carpentry 13 04-04-2007 03:16 PM
raising collar ties ajoantmug Building & Construction 9 03-18-2007 06:15 PM
Removing Collar ties Mike2004 Building & Construction 6 12-16-2006 02:48 PM
