View Poll Results: OK To Use Railroad Ties As Floor For Pole Barn/Shop?
Don't Know 1 6.25%
No - bad decision 13 81.25%
Never heard of RR ties for floor 1 6.25%
Seen it before and should be fine 1 6.25%
Yes 0 0%
Voters: 16. This poll is closed
Old 03-01-2009, 03:05 PM   #1
Federico
fcmazz's Avatar
Question Railroad
Hello,
I've just finished framing a 20x20 garage/shop and would like to use railroad ties as the floor. Wanted to know if anyone has had experience or heard of using RR ties as floor versus traditional concrete slab. On a budget right now and seems I can get the RR ties for $3 apiece compared to much more for concrete. I'm thinking RR ties would be strong and I can level them well one by one with my base frame. Any thoughts or ideas are welcomed.
fcmazz is offline   Reply With Quote
Old 03-01-2009, 04:26 PM   #2
Crazy, but lovable
flyboy2610's Avatar
The creosote smell would be unbearable on hot days.
flyboy2610 is offline   Reply With Quote
Old 03-01-2009, 04:28 PM   #3
Old School
Willie T's Avatar
Wow! That's going to take some wrapping my brain around. Truly interesting concept. Seems like you will be doing a lot of tongue and groove fabrication to key (lock) them together. And then about three days of sanding with 36 grit to begin with.
Probably have to resaw all of them first, too. I can see a beautiful, but stinky floor. Don't breathe the dust while you're sawing and sanding; it'll burn your throat raw! (Don't ask how I know. )
Willie T
Old 03-01-2009, 08:40 PM   #4
Put in a stone floor. If you do it correct it will be a suitable base for concrete when you get the cash.
You could also asphalt it. Cheaper than concrete.
Old 03-01-2009, 09:09 PM   #5
You will never be able to effectively sweep a railroad tie floor. Plus getting it level would be a pain. I would go for compacted 3/4" tb before I would put down railroad ties.
Give it a try before you die.
stubborn1 is offline   Reply With Quote
Old 03-01-2009, 09:53 PM   #6
It sounds like a really cool idea, it would look rustic. But, there are some health risks associated with railroad ties. I found this info on the MSU-Bozeman website. It's not the entire article, just bits and pieces of it.
Creosote is the black gue that railroad ties are treated with. Creosote has been classified by the Environmental Protection Agency (EPA) as a probable carcinogen. Studies have shown increased risk of cancer and respiratory problems in plant workers repeatedly exposed to creosote. Exposure to creosote on the skin has been shown to cause rash and irritation and in an extreme case, cancer. Direct skin contact with creosote poses the most likely health risks to people outside industrial applications. When handling creosote treated wood, wear gloves and long sleeves and try to minimize time spent working with ties. Work in well ventilated areas and avoid working in hot conditions when vapors are most potent.
gma2rjc is online now   Reply With Quote
Old 03-01-2009, 11:06 PM   #7
Toe stubs, splinters, and poison. Sounds like a damn fine floor to me.
It ain't Rocket science unless you are building rockets
Tscarborough is offline   Reply With Quote
Old 03-01-2009, 11:39 PM   #8
I have seen old shop floors made with beams like cross ties, but they had cut them into short pcs. and laid them end grain up.
7echo is offline   Reply With Quote
Old 03-02-2009, 10:00 AM   #9
Agree, with the health hazards
47_47 is offline   Reply With Quote
Old 03-02-2009, 10:48 AM   #10
I have seen it before. It does smell, and I wouldn't want to spend much time in there knowing it is a potential health hazard. I'd go with stone as mentioned and pour over it when you have the cash. You could lay down some patio blocks in work / parking areas.
Reilley is offline   Reply With Quote
Old 03-02-2009, 11:01 AM   #11
tomstruble's Avatar
concrete might not be as expensive as you think you still need a gravel base for the ties plus they tend to dull blades very quickly and are very heavy getting them all level and lined up could take awhile.redi-mix couple of hrs its done start using your shop alot quicker
tomstruble is offline   Reply With Quote
Old 03-02-2009, 02:19 PM   #12
Kyle Emerick
kemerick's Avatar
I agree, it would smell bad...
My constant project is my home which was built in 1947. I have remodeled almost all of it and am in the process of finishing off a 1000 square foot addition. Lars Construction got me up to drywall and I am doing the rest.
You can see many galleries of it located here under Galleries and then House.
kemerick is offline   Reply With Quote
Old 04-09-2009, 10:17 PM   #13
Federico
fcmazz's Avatar
Default Appreciate
All,
Thank you for the feedback on the railroad ties. I going with the majority and forget about this project. Probably stick to plywood or straight packed gravel.
Good luck on your projects.
FCMAZZ
Old 04-10-2009, 08:06 AM   #14
Household Handyman
Along the lines stated by 7echo, I also have seen many industrial floors built prior to "a long time ago" that were hardwood wooden blocks laid ends up. They, somehow, cut these back then so square that when laid they were very solid. I did some contract work in a textile mill back in the early '70's that had one entire floor, approximately 30,000 sq. ft. made entirely of this type flooring. They were driving fork lifts, and motorized pallet jacks on this floor. We were reluctant to drive in our 60K forklift and they insisted "you can't hurt this floor". It turned out we didn't even dent it. They used to coat this floor with the oils/fuel used to fire their huge boilers. That stuff was like molasses at normal S. GA. July temps. I really can't imagine the problems with making a floor with RR crossties laid flat, rounded edges, humped sides, etc.
Tags
railroad
More On This Topic
Hello my name is Dr. Susan Jewell. Now in this clip we're going to talk about some risk factors that predisposes particular male to getting prostate cancer. Now, what are some of the risk factors have been found? Well, one of the most important factor is... Read More »
Smoking & Menopause
Smoking & Menopause by Expert Village
Hello, my name is Dr. Susan Jewell, now in this clip we’re going to talk about some of the ways what you can do to reduce the symptoms of menopause like hot flashes. Now if you smoke, it’s going to increase your risk of getting osteoporosis... Read More »
Hello my name is Dr. Susan Jewell and in this clip I am going to talk to you about certain ways to reduce the risk of getting prostate cancer in a series of clips on how to check for prostate cancer. What are some of the things that you can actually eat... Read More »
Common Prostate Problems
Common Prostate Problems by Expert Village
Hello, my name is Dr. Susan Jewell, and on behalf of Expert Village today I'm going to talk to you about how to detect prostate cancer. In other words, how can you see some of the signs and symptoms and what do you need to do to reduce the chance of... Read More »
It is difficult to prevent ovarian cancer, because the risk factors are not aspects of life that most people have control of. Ovarian cancer, the cancer in which tumors develop on or inside a woman's ovaries, does not have a known cause, but there are... Read More »
Railroad Tie Retaining Wall - long wall adjacent to driveway wauf Carpentry 0 01-07-2009 11:34 AM
Railroad Ties Wall & Black Widow Spiders Dona Pest Control 4 09-06-2008 06:04 PM
railroad tie retaining wall david81 Landscaping & Lawn Care 16 09-02-2008 07:38 PM
Replacing Railroad Tie Retaining Wall Msfixit Landscaping & Lawn Care 2 07-24-2008 10:03 AM
Railroad ties- what are the downsides? lanispet Building & Construction 4 03-31-2008 04:12 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
