Old 05-25-2009, 01:30 PM   #1
Railing Around Stairwell - Code?
Hi....Can someone tell me the minimum height of a railing surrounding a stairwell on the second floor of a house? I am in Canada, so it may be different from the US. I know the railing height on the stairs themselves is 32-36" in Canada. Thanks! M
Melanie337 is offline   Reply With Quote
Old 05-25-2009, 03:24 PM   #2
Moderator
Look at Guardrails, here:
http://www.hpo.bc.ca/PDF/BuilderInsight/BI2.pdf
You need to check your local code here:
http://www.about-building-in-canada....ing-codes.html
http://rapidlibrary.com/index.php?q=...code+of+canada
Be safe, G
Old 05-25-2009, 04:09 PM   #3
Thanks GBAR...got what I need...railing on stairs 32-36" and on second floor around stairwell, it's 36" minimum.
Extending height of deck railing tntworks General Discussion 4 03-11-2013 08:16 AM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 08:52 AM
Question about stairwell width jonblack Building & Construction 40 09-22-2008 10:48 AM
How to fix broken step railing? robertr4836 Carpentry 2 04-18-2008 12:19 PM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 02:47 PM
