Rafters Pushing The Wall Out - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-13-2006, 12:26 PM   #1
rafters pushing the wall out
Hi everyone!
I am new to the forum I am in the process of buying a house. Home inspectotion revealed that one of the walls ( 2nd floor) is leaning outwards being pushed by rafters.
Can someone tell me if this is a serious problem? Could this be fixed? If yes, should i anticipate this problem to recur in future? Would it have any effect on resale value of the home?
Christy
christy123 is offline   Reply With Quote
Old 10-13-2006, 01:54 PM   #2
I would get 3 or more estimates on how much this will cost to repair.
Ask the contractor if it can be fixed, how serious the problem is and if there are any other problems associated with this slanted wall.
If you find that the problem can be fixed for a modest price and will be stable/safe in the long run then you could proceed with the purchase.
If you found out by the contrator that this is serious problem and the cost will be high then you could walk away from the property or get the seller to reduce the price of the home to make the repair.
Was this problem noticeable when you looked at the house?
The rafters should not push the walls outward if there are ceiling/attic joists. The attic joist should hold the walls from spreading away from the rafters. Or there should rafter ties that hold the roof from spreading.
Have you gone into the attic and looked for any further probelms?
redline is offline   Reply With Quote
Old 10-13-2006, 01:57 PM   #3
How much does the wall push outward?
How much of the wall length is leaning? (1 foot, 5 feet, 10 feet...)
Did you ask the owner how long this problem is been left like this?
If you look at the roof from the exterior, are there any dips, sags or other problem?
Could you post a photo of the problem?
Old 10-13-2006, 03:25 PM   #4
Well..it wasnt obvious to me from outside when i looked at it. 2nd floor cieling and this leaning wall did have some gap of about an inch . I did go into the attic with the inspector...there was about a gap of 6 inches on this side of the house. roof has sags.. it is very old...
ownner denied he knew anything about this. house is old ..was built in 1920s.
Seller agreed to pay for the repairs but my concern is whether the property would lose value after repairs . would i have difficulty in reselling the house should i need to.
Old 10-13-2006, 07:51 PM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
As suggested, you should get some estimates on the cost to fix.
It sounds like it could be?:
Broken or damaged rafters at that point.
Separation of rafters from the ridge beam.
It is hard to tell...as it depends on the type of framing as well...Balloon framing?
If it is repaired, it will not effect the value of the home at all. (Home repairs are not like a car that has a bent frame and has been repaired)
Also:
Remember that estimates are usually free 99% of the time.... in the contracting field.
BTW- Just remember that a house in such a condition, built in the 1920's may require other work.....$$$
Good Luck.
- Build Well -
Old 10-13-2006, 07:54 PM   #6
Hi everyone!
Christy
Did the home inspection find any other problems with the house?
Old 10-13-2006, 07:59 PM   #7
How old is the furnace?
How old is the roof? How many layers of shingles?
Is the foundation in good shape?
Is there water in the basment or prior presence of water?
Is the plumbing copper? If it is older plumbing then it may need updating.
How old are the water and sewer lines going to the public road way?
How old is the electrical system? Is it breakers or fuses?
How many amps to the main electrical panel?
How old are the windows? Do they need replacement?
Is the exterior maintenance free or will it require painting?
Is the house insulated?
Old 10-13-2006, 08:11 PM   #8
Furnace is very old but inspector said that there would be no issues in near future..
Roof is > 20 years old ...seller had agreed to pay for it even before the inspection..it is 2 layer shingles.
Foundation is in good shape but they had water last year during heavy rains...there are no drains or sump..
plumbing is mixed..old and new
water and sewer lines are old....
Electric system is breaker and they have mix of old and new wiring
most of the windows have been recently...
exterior is clap board would need paint....house is insulated.
Old 10-13-2006, 08:12 PM   #9
electrical is 100 amps
Old 10-13-2006, 08:26 PM   #10
If the furnace is older than 10-15 years old then it may be better to lower your purchase price because a new system may cost over $5,000 depeding on the size.
Make sure that they tear of all layers and put on a completely new roof or adjust the pruchase price lower to reflect the cost. A new roof may cost close to $10,000 depending on the size.
Is this a dirt floor basement or cement ?
Is the a basement finish and used as living space or just storage?
If it is not all copper than it may have galvanized pipe which should be changed to copper. The price of copper has tripled over the past year. You may want to lower the purchase price to reflect replacing the plumbing.
This can be expensive to replace because the ground will need to be dug up. How far is the house from the road or water and sewer tie in? The longer the run the more expensive the cost.
Any areas of lead based paint or asbestos?
Old 10-13-2006, 08:40 PM   #11
Is this the first house you have ever purchased?
It was a very good decision to have an inspector. Does the inspector offer a warranty on his evaluation?
Old 10-13-2006, 08:45 PM   #12
yes this would me first house...
basement has asbestos tiles... lead is expected in a home this old...
i dont believe inspector offers warranty but he is from a very reputed company
Old 10-13-2006, 09:20 PM   #13
I had taken this into consideration when made the offer...my offer was baout 15% lower than asking price
will take this into consideration------
basement has cement ... it is part finished ...there is bar in the basment...it probably was used for entertaining and parties
House is right off the street..
Old 10-13-2006, 10:09 PM   #14
remodeling pro
Potential for a costly repair. The ceiling joists normally act to tie the outside walls together so they can't be pushed by the thrust of the rafters. There is either way to large a spacing on the ceiling joists( a not too common occurance, but I have seen this in old houses), remember lots of these houses were not professionally built, and there were no codes then, or insufficient fasteners are failing at the ceiling joist/ top plate connection; this was only a couple of toe nails before metal connectors were required.
troubleseeker is offline   Reply With Quote
Old 10-14-2006, 11:43 AM   #15
ok ..i had a structural engineer take a look at the property. He was more optimistic. He said birds mouth of the rafters were slipping off. he said it will continue to move outward about an inch in next 70 years. he advised against pulling back the wall. instead h said movement could be slowed by putting a knee wall under the rafters and removing current 2 or 3 layer roof and replacing it with one layer.
what you guys think?
Replace Cripple Wall to Raise Foundation? casey_wa Building & Construction 1 08-04-2007 04:32 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 03:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
