Rafters - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-06-2013, 03:29 PM   #1
Rafters
My roof rafters are only 2+6s. Can I sister 2+8s right next to each one to make room for insulation n lights n would I need to lay new rafters on top of wall plate n other end nailed to ridge beam
ecocco1469 is offline   Reply With Quote
Old 03-06-2013, 03:32 PM   #2
It's also a vaulted ceiling so it will b getting new sheet rock on it also
Old 03-06-2013, 03:49 PM   #3
Rewards Points: 150
What is your location and how much insulation are you considering to install? Are you providing for ventilation? I ask as 2 X 8s if sistered along side the 2 X 6s and up against the sheathing, may not give you enough space. What is the span and pitch? do you have room to construct an independent frame that is beneath your existing roof rafters? Recessed lights in a vaulted ceiling are never energy efficient.
TheCamper is offline   Reply With Quote
Old 03-06-2013, 04:03 PM   #4
I'm on Long Island New York. It's one story ranch. My kitchens vaulted already. But what I really wanted to see if I could do was to get 2+8s n place them on top of wall plate at bottom of ceiling. N then instead of nailing them to the 2 by 6 I wanted to make a new ridge beam underneath my old one n this way my pitch would not be as my old one but it would give me plenty of room for insulation n lights. The span from wall to ridge is about 14 ft. Yes I plan on leaving room for air travel
Old 03-06-2013, 04:07 PM   #5
So basically at bottom of roof I would have 8 inches n at top I would have about a foot depending on how much of a pitch I give it. Just wondering if this would b able to work. I would build new ridge beam under old one n I'm planning on bracing it up good
Furring out existing 2x6 rafters kirylm Building & Construction 27 02-13-2012 11:10 PM
Insulating 2x4 attic ceiling rafters help needed tseverson Insulation 2 11-01-2011 08:57 PM
Insulating flat roof with exposed rafters rblevow Insulation 1 05-14-2011 11:00 PM
checking the rafters joefromcal Carpentry 3 10-01-2010 09:12 AM
Replacing rafters, but no ridge board WillK Building & Construction 0 08-29-2010 09:44 AM
