Rafters For 10 X 10 Garden Shed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-23-2011, 09:24 AM   #1
Old Hand
Rafters for 10 x 10 Garden Shed
I am building a 10 x 10 garden shed with 1/2 plywood paneling on the outside. The ridge beam is 2x6. The rafter overhang is 3". I can't find any articles on how to cut these rafters since the pitch is so low. Anyone know of an online reference guide or can you tell me how to use my framing sqaure to figure out the angles for both the plumb line at the ridge beam and for the birds mounth. Thanks
iliketowork is offline   Reply With Quote
Old 10-23-2011, 09:34 AM   #2
Framing Contractor
I can help you but what does the pitch being so low have to do with anything? What size rafters are you using? Are you framing the whole shed first and then sheathing?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 10-23-2011, 10:16 AM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
the lower the slope the greater the snow load as the snow wont slide off the roof like it will on a 12/12, the lower the slope i would be more inclined to up the size of the rafters to lessen the chance of them sagging under snow and wind load
woodworkbykirk is offline   Reply With Quote
Old 10-23-2011, 10:57 AM   #4
Framing Contractor
I wanted to know what a low pitch has to do with cutting rafters compared to a higher pitch.
Joe Carola
Old 10-23-2011, 12:53 PM   #5
Residential Designer
AndyGump's Avatar
Rewards Points: 664
Send a message via Skype™ to AndyGump
He doesn't have to worry about snow load, he is in Silicon Valley CA.
To the OP, what is the pitch of the roof?
Andy.
AndyGump is offline   Reply With Quote
Old 10-23-2011, 10:13 PM   #6
Old Hand
Rafters are 2 x 4.
Hi Joe:
Rafters are 2 x 4 since there will be virtually no load (I am in Silicon Valley so there is no snow). I am framing and sheathing first as two sides are 6" from the fence line.
My inability to use the framing square for a low pitch is due to my inexperience cutting rafters: I only see "whole numbers" and can't figure out what pitch only rises about 1" per foot. All I need is for the water to run off the roof as I am going to use composition roll.
Old 10-24-2011, 09:04 PM   #7
Framing Contractor
Hi Joe:
1" per/foot would be a 1:12... same as if it were to rise 5" per foot...that would be a 5:12...you hold the framing square for a 1:12 pitch on the 1" mark and the 12" mark....for a 5:12...you would hold the framing square on the 5" mark and the 12" mark.
Joe Carola
The Following User Says Thank You to Joe Carola For This Useful Post:
iliketowork (10-25-2011)
Old 10-25-2011, 10:00 AM   #8
Old Hand
Thank You
That's what I get for trying to outthink this. Appreciate all of your help.
Old 10-25-2011, 01:55 PM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Hi Joe:
I would not build 6" from a fence line. First there may be a setback requirement by the town. And even if not, you need to move around it for maintenance. I would go no less than 2 feet and 3 is better.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
iliketowork (10-26-2011)
Tags
birdsmouth cut , rafters
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 34 09-15-2015 07:23 PM
Running power to garden shed Tryvidy Electrical 6 07-29-2011 05:13 PM
underground conduit to power up a garden shed HappyHome Electrical 5 08-11-2010 04:46 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
Building rafters for small shed simonb Roofing/Siding 4 07-15-2008 01:32 PM
