Rafter Vents - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-16-2012, 09:05 AM   #1
rafter vents
when installing rafter vents...do they need to be full length---eave to ridge---or just long enough to clear the depth of the insulation ?
pattiann4 is offline   Reply With Quote
Old 09-16-2012, 09:22 AM   #2
Rewards Points: 13,712
Are you talking about foam or plastic baffles?
If so they just need to clear the insulation.
Old 09-16-2012, 09:58 AM   #3
rafter vents
yes, I am using the foam baffles/vents.
Old 09-16-2012, 01:14 PM   #4
GBrackins's Avatar
Rewards Points: 2,108
insulation baffles are installed prevent insulation from blocking the air flow from your soffit vents to the ridge vent. therefore they should extend above the insulation.
I like the following baffle http://www.owenscorning.com/around/v...s/VentSure.pdf it blocks air flow (windwash) from the soffit vent through air permeable insulation. cold air running across a warm ceiling can lead to condensation.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
Duckweather (09-16-2012)
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing/Siding 1 09-07-2011 10:13 AM
Are rafter vents always needed? SonOfPirate Insulation 7 08-08-2011 06:20 PM
Rafter vents & insulation question k.kuenn Roofing/Siding 15 01-29-2011 11:34 PM
removing rafter ties: garage conversion neil_9 Introductions 0 09-29-2010 07:55 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
