-   -   rafter vents (http://www.diychatroom.com/f19/rafter-vents-156956/)
pattiann4 09-16-2012 09:05 AM
rafter vents
when installing rafter vents...do they need to be full length---eave to ridge---or just long enough to clear the depth of the insulation ?
joecaption 09-16-2012 09:22 AM
Are you talking about foam or plastic baffles?
If so they just need to clear the insulation.
pattiann4 09-16-2012 09:58 AM
rafter vents
yes, I am using the foam baffles/vents.
GBrackins 09-16-2012 01:14 PM
insulation baffles are installed prevent insulation from blocking the air flow from your soffit vents to the ridge vent. therefore they should extend above the insulation.
I like the following baffle http://www.owenscorning.com/around/v...s/VentSure.pdf it blocks air flow (windwash) from the soffit vent through air permeable insulation. cold air running across a warm ceiling can lead to condensation.
