#1 |
rafter ties do they go inside or outside of walls?
Im tying my rafters down on the top plates using simpson h rafter ties. Do they go on the inside or outside? Thanks
#2 |
Lic. Builder/GC/Remodeler
Interior side.
- Build Well - |
#3 |
Thank you. Is it normal to only be able to notch my 2x12 rafters only 1/6 th of the board to my top plate?
#4 |
Mod
That's where I've always put them but if you look at the Simpson site they show them all on the outside.
A Picture Is Worth A Thousand Words Especially In The DIY Chatroom -NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State. |
#5 |
If you put them on the outside you dont have to deal with them when you sheetrock. They can go on either as long as the inspector can see it.
In most cases the outside will be closed up by the time you go for a final frame. But you can get it on the sheathing inspection if they have them where you are.
If my advise helped you hit "Thanks" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following 2 Users Say Thank You to Hammer450R For This Useful Post: | AtlanticWBConst. (09-06-2012), oh'mike (09-03-2012) |
#6 |
Thanks to all. My plans dont allow me to cut more than 1/6 of my rafter for a birds mouth to lay on my top plate. Is this normal for rafter strength?im using 2 x12 so i can only notch in 2 inches.
#7 |
2 inch should be fine depending on the pitch. You just dont want to cut more than full bearing on the wall.
#8 |
are you installing wood sheathing on the exterior side of the wall?
see your other post for my reply on notching rafter notching rafters depth help please
Gary "You get what you pay for, and sometimes free costs more!" |
#9 | |
Framing Contractor
rafter ties do they go inside or outside of walls?Quote:
Joe Carola |
#10 |
does you plan say you may not notch a joist or rafter more than 1/6? if so, a bird's mouth is not a notch, it is a seat cut
#11 |
Outside, to prevent "topplate roll" http://www.strongtie.com/ftp/bulleti...ECONPATH10.pdf
| The Following User Says Thank You to tornstrom For This Useful Post: | GBrackins (09-05-2012) |
#12 |
#13 |
Good stuff Tornstrom
#14 | |
you can install them on the interior side, you just have to add a stud plate connector (SSP) on the interior side, or a H2.5 will work also. this will connect the top plates to the stud to prevent the roll. I like the H2A or H10S as they are allowed for interior installation and will connect the rafter/truss, top plate and stud together in a single connector.
#15 |
Ill look into it. Thank you.
| Display Modes | |
| Looking for input | nikeman | Building & Construction | 10 | 04-07-2012 10:18 PM |
| Cutting rafter ties ?? | scatkins | Building & Construction | 23 | 04-13-2010 04:20 PM |
| Rasing rafter ties and Venting Question. Does AtlanticWBConst. Still Frequent? | gregt848 | Building & Construction | 11 | 09-24-2009 09:46 PM |
| Clicking inside walls after use of water | Jax newbie | Plumbing | 4 | 02-23-2008 01:48 AM |
| Rafter Thrust / Cathedral Ceiling | sseeley | Carpentry | 8 | 10-06-2005 12:19 PM |
