Rafter Ties - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-07-2011, 09:17 PM   #1
Question
rafter ties
Can I splice 2x8 for rafter ties I need to span 22' if so how is it done? How are the double top plates spliced? Thanks Granpa
Granpa is offline   Reply With Quote
Old 03-07-2011, 09:32 PM   #2
Framing Contractor
Just by 22' 2x8's.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 03-09-2011, 02:39 PM   #3
I want to use some of the lumber I have around the yard 2"x8"x17' 18 ea. Buying new is not always an option. I like to recycle when I can.
Old 03-09-2011, 04:11 PM   #4
Framing Contractor
What is this for? New addition, garage, remodel?
Joe Carola
Old 03-10-2011, 11:04 AM   #5
Garage 22'x22'
Old 03-10-2011, 08:09 PM   #6
Yes you can splice a rafter tie. Hang them with 1x4 from the rafters.
Tigerloose is offline   Reply With Quote
The Following User Says Thank You to Tigerloose For This Useful Post:
Granpa (03-11-2011)
tension wire as rafter ties?? Wolfen Building & Construction 9 03-01-2011 11:21 AM
removing rafter ties: garage conversion neil_9 Introductions 0 09-29-2010 07:55 PM
Cutting rafter ties ?? scatkins Building & Construction 23 04-13-2010 03:20 PM
Garage Rafter Ties - Can I remove them? cmj Building & Construction 6 02-02-2010 10:57 AM
Rafter Ties on Vaulted Ceiling timsgills Building & Construction 2 01-07-2010 03:02 PM
