Rafter Ties - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-08-2013, 02:42 PM   #1
rafter ties
Hi,
Anyone recommend a good rafter to ridge connector. I tried one from Lowes today and it would not keep the rafter flush to the ridge. Also, when the rafter sits on the top plate do you need a hurricane tie on the inside and outside. If you put one on the inside wouldn't that prevent the ceiling joist from laying flush next to the rafter?
markharmon is offline   Reply With Quote
Old 05-09-2013, 06:33 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
a 2x4 nailed under the ridge board against the sides of the rafters works. Looks like the letter A
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-09-2013, 07:06 PM   #3
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
Maybe I don't understand but you could just toe nail the rafters to the ridge and put a rafter tie in as Gary suggested.
Hurricane ties work on both inside and outside. As far as the ceiling joist not laying flush, just flip the tie around and put it on the other side of the rafter.
Edit: I just realized that you probably have the diamond shaped rafter ties, those won't work with the ceiling joists.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Number of rafter ties in an 18' x 18' detached garage cjkb Building & Construction 19 03-13-2013 09:31 PM
Rafter Ties Moritasgus Building & Construction 14 01-21-2013 04:08 PM
Collar ties or rafter ties? jvetter713 Building & Construction 4 03-31-2012 09:36 AM
removing rafter ties: garage conversion neil_9 Introductions 0 09-29-2010 07:55 PM
