Old 08-09-2007, 04:51 PM   #1
I have gas!
Clutchcargo's Avatar
rafter spacing
Sorry about all these newb questions.
I'm just putting up the rafters in my portico now. I've got the two end rafters up. The space is 38" where I need rafters. Do I evenly space them or keep as many on sixteens and have the last one spaced differently.
TIA
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 08-09-2007, 05:02 PM   #2
Agent 000
SecretSquirrel's Avatar
rafter spacing
I'd say to take no chances and set on 16's... that way if you're sheathing with some kind of 48" wide material it will line up no matter what.
SecretSquirrel is offline   Reply With Quote
Old 08-10-2007, 07:22 PM   #3
rafter spacing
16 OC see my other post.
jiggyjack is offline   Reply With Quote
Old 08-11-2007, 05:48 AM   #4
General Contractor
joasis's Avatar
rafter spacing
Split the distance, since you are working out material lengths, it would be fine. We typically frame on 24's for roofs, rarely on 16's. If you notice, on tape measures, there ie a black diamond mark at about 19 and 3/8 inches, repeating. This splits 16 and 24 to make 5 spaces in 8 feet instead of 4 or 6.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 08-11-2007, 09:38 AM   #5
I have gas!
rafter spacing
I'm going to wrap up the framing today.
Let me see if I have this right,
my choice is to either:
Evenly space the rafters @ 12.75" OC for a total of 4 rafter sets (1/2 ply)
Space @ 16s with the outer 2 sets of rafters at about 5" OC (1/2 ply)
Or just add one more set of rafters spaced at around 19.5" (3/4 ply)
All of these will pass code, correct?
Also attaching the rafters to the top plate I'm both using hurricane ties and toe nailing through the birds mouth. Is that correct?
Old 08-11-2007, 03:14 PM   #6
General Contractor
joasis's Avatar
rafter spacing
Yep....no law against over building anything.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
spindle spacing jibber Carpentry 5 02-18-2007 09:30 PM
rafter tail rott mohamie Roofing 8 09-27-2006 06:28 PM
Rafter Thrust / Cathedral Ceiling sseeley Carpentry 8 10-06-2005 12:19 PM
Cost of replacing a rafter in our roof??? bikerboy337 Roofing 3 04-24-2005 07:19 AM
