Rafter Seat Cut Options - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-18-2013, 12:55 PM   #1
Rewards Points: 20
Rafter seat cut options
Traditionally most rafters have a birds mouth cut where they rest on the top plate (as shown on the left).
Is there any reason not to cut the seat as shown on the right with the rafter tail reduced in height?
Is there a code or practical reason for sticking with the birdsmouth?
I want to use the style on the right to leave more room for air to circulate in the eaves and eliminate the need for continuous soffit vents in a cathedral ceiling.
Tubafore is offline   Reply With Quote
Old 06-18-2013, 01:07 PM   #2
Rewards Points: 13,260
I'm not seeing anyway the one on the right is going to give you more.
Looks like a lot less to be.
Unless your going to have this ceiling spray foamed I see no way your going to fit the required amount of insulation plus the baffles in that small an area.
http://www.energystar.gov/index.cfm?...sulation_table
Old 06-18-2013, 01:20 PM   #3
Rewards Points: 20
There will be a build down framework on the interior to give me the needed insulation depth.
Old 06-18-2013, 01:44 PM   #4
Rewards Points: 502
Structurally there is no problem with the detail on the right.
tony.g is offline   Reply With Quote
Old 06-18-2013, 01:49 PM   #5
Old School
Willie T's Avatar
You do understand that no matter the point of narrowing the rafters, a smaller fascia makes the house look cheaper. That's why trusses with just 2x4 top chords (tails) have larger 2x6 or 2x8 "hang-down" sub-fascias added to them.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
tony.g (06-18-2013)
Old 06-18-2013, 02:08 PM   #6
Rewards Points: 20
The fascia will still be about 7" tall. This is an addition and it will match up well with the existing house.
Old 06-18-2013, 02:13 PM   #7
Old School
Willie T's Avatar
Then I see no problem.
Willie T
Old 06-18-2013, 02:33 PM   #8
Rewards Points: 20
Awesome, thanks.
Old 06-18-2013, 03:59 PM   #9
GBrackins's Avatar
Rewards Points: 2,108
I take it you are doing the work yourself? I ask because the additional time required to build down the ceiling for more insulation space.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 06-18-2013, 06:04 PM   #10
Rewards Points: 20
Yes I will be doing the work myself. There are a few reasons I chose this design. Even a 2x12 wouldn't give me the depth I needed for insulation without pricey spray in foam.
With R-38 batts plus the 1" foam board I will be using to create an air space this will give me a total R-44 value. Plus the drop down will break the thermal bridging that happens through solid lumber. All at a pretty reasonable price tag.
The Following User Says Thank You to Tubafore For This Useful Post:
woodworkbykirk (06-18-2013)
Old 06-18-2013, 06:08 PM   #11
GBrackins's Avatar
sounds good, thanks for sharing
Gary
Fascia board install - unlevel rafter tails giperbolic Roofing/Siding 3 01-18-2012 12:46 AM
Rafter Calculations - help me understand, please. wombosi Building & Construction 25 09-11-2011 11:48 AM
Rafter tie adjustment albanello Building & Construction 10 11-20-2010 11:26 PM
removing rafter ties: garage conversion neil_9 Introductions 0 09-29-2010 08:55 PM
Rotted Lookout Beam Supporting Barge Rafter rwbil Building & Construction 1 08-15-2010 12:40 PM
