Old 09-17-2008, 03:29 PM   #1
rafter length
Who wants to help me with my math??? I need to order rafters for a barn I'm building- 30' wide with an 8:12 pitch. I've gotten this far: 15' run with a 10' rise. (run sq. + rise sq. = x sq. = rafter length) so 225 + 100 = 325 sq. = 18.027756. So 18' and how many inches? I will have a foot of overhang so looks like I should order 20' lumber. The foot of overhang I plan on "walking off" with my framing square. I understand I can figure entire length this way but too much room for error in my opinion. Thanks for the math lesson!!!
ugabulldog is offline   Reply With Quote
Old 09-17-2008, 04:28 PM   #2
RippySkippy's Avatar
rafter length
Check this link out...it from a book titled Measuring, Marking and Layout: A builders guide by John Carroll and is a snipet from google...it'll explain it in excruciating detail! And the good old standard from Stanley(be cautious it will download a PDF of the rafter square manual) pretty poor quality...but readable.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 09-17-2008, 05:24 PM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
rafter length
8" pitch with a 15' run including a one foot over hang requires a 19'-3" rafter minus 1/2 the thickness of the ridge. your rise would be 10' -0". Your total lenght of your rafter would be 18"-1/2" plus 1'-2 1/2" for your overhang. = 19'-3"
Good luck BOB
Old 09-17-2008, 05:30 PM   #4
STAFF
BigJim's Avatar
rafter length
A2+B2=C2 216.33307 inches minus 1/2 the thickness of your ridge board.
BigJim is online now   Reply With Quote
Old 09-18-2008, 04:22 PM   #5
rafter length
thanks and thanks........... I had an old framer tell me once that instead of subtracting 3/4" (half the ridge board) he only subtracted 1/2" so the rafter would set tighter against the ridge. He showed me this after my rafters/ridge fits had a gap at the bottom. Any comments on that??
Old 09-18-2008, 07:24 PM   #6
Framing Contractor
rafter length
That doesn't make any sense. If you subtract 1/2 the thickness of the ridge and cut the rafter the right length and your walls are parallel the rafter will fit perfect without any gaps. If you had a gap, you must have something wrong with the length of your rafter or the plumbcut wasn't right, or the walls bowed.
With a 15' run and a 2x ridge, you effective run is 14' 11-1/4". 8/12 pitch, your rafter length to the outside of the top plate will be 17' 11-7/16". Your 1' overhang, add another 1'2-7/16".
Joe Carola
Joe Carola is offline   Reply With Quote
need some rafter help feralfreak Carpentry 5 07-30-2008 07:48 AM
rafter questions - structural rtoni Carpentry 11 09-13-2007 06:40 AM
Rafter Thrust / Cathedral Ceiling sseeley Carpentry 8 10-06-2005 12:19 PM
