Rafter Framing Code Question - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-21-2011, 10:02 PM   #31
Framing Contractor
Originally Posted by anesthes View Post
I'm not going to argue with the building dept.
It's not worth it at all.
It looks like the metal straps are the best bet, and if I go with a 2x8 ceiling joist I can run a single top plate on it which is probably better in the end, even if a 2x6 would work.
-- Joe
Single or double plate doesn't matter. I've had them spec'd both ways. I've used 2x4's and 2x6 top plates
Joe Carola
Joe Carola is offline   Reply With Quote
Old 01-21-2011, 10:03 PM   #32
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
"This isn't about structure, this is about energy savings. Do you realize how much money you will save over the years".
I have to laugh at that because I am sure that he doesn't "know" how much anyone would save over the years. I am sure there is an entire calculus for figuring the energy savings on something so small but my common sense tells me that it just would not be worth it.
Andy.
AndyGump is offline   Reply With Quote
Old 01-21-2011, 10:43 PM   #33
Registered User
Rewards Points: 526
Sorry Joe, my span was for 20# live load, limited storage. You will want the first table, IF under the 2009 IRC; http://publicecodes.citation.com/ico...002_par023.htm
Check your State Energy Code on-line for the requirements and reduction for sloped roof. That is what the AHJ (authority having jurisdiction) does. My State is one of the few with it's own Energy Code......
Gary
Follow up code question RE: 312.5(C) tigereye Electrical 3 01-05-2010 03:41 PM
Door Framing Question biggidybankston Carpentry 4 12-10-2009 12:26 PM
Simple question on 16" O.C. framing TitaniumVT Building & Construction 10 11-27-2009 06:51 PM
Gun nail question - framing starts in 3 days RolandOG Carpentry 4 08-05-2008 08:07 PM
Code - Framing Under 2nd Floor Bathtub austinbirdman Building & Construction 2 03-04-2007 02:14 PM
