Rafter Cuts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-11-2011, 06:13 PM   #1
Question
rafter cuts
Is it neccessary to cut a birdmouth into the rafters if I am using metal tie brackets to tie the rafters to the walls? or can i just let them ride on the top plates? They will be nailed to the joists atop the wall.
Robert King is offline   Reply With Quote
Old 03-11-2011, 10:02 PM   #2
Registered User
Rewards Points: 4,912
R802.6 Bearing. The ends of each rafter or ceiling joist shall have not less than 11/2 inches (38 mm) of bearing on wood or metal and not less than 3 inches (76 mm) on masonry or concrete. http://publicecodes.citation.com/ico...002_par023.htm
Welcome to the forum!
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Robert King (03-13-2011)
Old 03-12-2011, 11:25 AM   #3
Framing Contractor
They make a bracket that gets nailed to the top plate and the rafter sits into it and you nail the bracket into the rafter. That's a waste of time. I've never once seen it done Cut the birdsmouth and nail it to the top plate. It's easier and faster.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
Robert King (03-12-2011)
Old 03-13-2011, 11:37 AM   #4
Thankyou for the advice-I'm going to do whar you said. I've never tried it the otherway either,but thought I could save the hassle of making those cuts.have a good day. Robert
Old 03-13-2011, 11:48 AM   #5
Framing Contractor
What is the pitch, span rafter and ridge size?
Joe Carola
Old 03-13-2011, 12:11 PM   #6
Cool
pitch etc...
The span is 15', the pitch is 3/12, the ridgeboard is a 2x. I've already set the gable end pair of rafters. I can only do one end now because it is an addition to a home, the new roof steps up 9-1/2" over the existing roof. The new ridge is offset 3'-6" from the existing. I don't want to tear up the existing overhang yet because I'm expecting rain so I'm going to build the gable wall and set all the rafters except the last pair and the barges today. This will be a very lightweight metal roof so that's why I'm using the hurricane ties (simpson). I've seen roofs flip off before and land in a backyard in one piece! On a Motel believe it or not! It was around 150' long! Robert
Rafter tie adjustment albanello Building & Construction 10 11-20-2010 11:26 PM
rafter cuts, etc bkb2307 Building & Construction 16 10-03-2010 04:35 PM
removing rafter ties: garage conversion neil_9 Introductions 0 09-29-2010 08:55 PM
Rotted Lookout Beam Supporting Barge Rafter rwbil Building & Construction 1 08-15-2010 12:40 PM
Moving Attic Access -- Same Rafter or Different ?? wrldruler Carpentry 1 10-19-2008 07:03 PM
