Rafter Cable Ties - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-30-2014, 07:43 PM   #1
Rewards Points: 109
rafter cable ties
I cant understand this math. ive been over and over it. Each time I get a little further, then I loose it again.
ref:
How to calculate rafter thrust? -Help! at http://www.eng-tips.com/viewthread.cfm?qid=105386
Can someone help me figure cable load?
4/12
24" rafter spacing.
No rafter ties at all. A few existing collar ties.
ceiling joists run parallel to ridge.
house is 27' x 30'(ridge).
7/8" roof planking and asphalt shingles.
thanks,
pa
paulmars is offline   Reply With Quote
Old 05-30-2014, 08:40 PM   #2
Rob
Robpo's Avatar
Rewards Points: 826
not sure what we a suppose to look at on link
Robpo is offline   Reply With Quote
Old 05-31-2014, 09:59 AM   #3
GBrackins's Avatar
Rewards Points: 2,108
try this ....
http://www.timbertoolbox.com/Calcs/RafterThrust.htm
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-31-2014, 10:02 AM   #4
Rewards Points: 109
Originally Posted by GBrackins View Post
I dont know "Load on Rafter (pounds/sq ft)"
pa
Old 05-31-2014, 10:54 AM   #5
Rewards Points: 502
pa
You can work out the dead load of your roof by looking in books or tables showing the weight in lbs/per sq ft of various materials.
To this you add the live load - principally snow load - which your local building inspector will be able to tell you.
You add the dead load to the live load to give a total maximum load in lbs/sq ft.
tony.g is offline   Reply With Quote
The Following User Says Thank You to tony.g For This Useful Post:
GBrackins (05-31-2014)
Old 05-31-2014, 10:59 AM   #6
GBrackins's Avatar
thanks tony!
Gary
Old 05-31-2014, 11:21 AM   #7
Rewards Points: 109
no snow here
Old 05-31-2014, 12:26 PM   #8
GBrackins's Avatar
your building code will specify your live load requirement. if you don't know your code your building official will be able to provide that to you.
dead load is the weight of the materials used in the construction of your roof. roof dead load can vary from 10 pounds per square foot upwards, all depends on the materials used.
Gary
Old 06-14-2014, 07:37 PM   #9
Rewards Points: 109
I dont know what type of woods used.
Good Quality Cable Ties? smata67 Electrical 7 01-21-2012 07:57 AM
Rafter tie adjustment albanello Building & Construction 10 11-20-2010 10:26 PM
Plastic cable ties ODDJOB72655 Electrical 5 07-20-2010 05:07 AM
Garage Rafter Ties - Can I remove them? cmj Building & Construction 6 02-02-2010 10:57 AM
Raising ceiling, using rafter ties cibula11 Building & Construction 23 01-20-2010 06:38 PM
