-   -   rafter birdsmouth and wall sheathing ??? (http://www.diychatroom.com/f19/rafter-birdsmouth-wall-sheathing-48536/)
Clutchcargo 07-10-2009 08:11 AM
63 Attachment(s)
Do you cut a rafter birds-mouth so that it sits on top plate including the wall sheathing (4" for a 2x4 wall with 1/2" CDX) or make the cut to the top plate and butt the sheathing up to the bottom of the birds-mouth?
So sheath the wall first and then cut the rafters or cut the rafters first?
My house has the construction where the builders sheathed first and then cut the birds-mouth.
Scuba_Dave 07-10-2009 09:53 AM
I usually sheath 1st, then do the rafters
Sheathing ties everything together so it won't move
On my cabana addition I did the bottom 3' with cement board then the rafters, then the rest of the sheathing
The old siding on the existing cabana rotted out at the bottom
So I used cement board on the bottom 3' to prevent rot
Joe Carola 07-10-2009 02:04 PM
Depends whether you sheath the walls first or after the walls are up. I sheath after the walls are up, so the birdsmouth is the width of the rafter.
Gary in WA 07-10-2009 03:06 PM
So long as you tie the bottom top plate with the wall sheathing, for shear. If the rafter tails are left full thickness, as in a closed soffit, they may be in the way of that. Otherwise, you could add blocking across the top for shear-flow, a lot of extra work. Remember the nailing room required for the top of wall nailing if you sheath the roof overhangs first. Be safe, G
Wildie 07-10-2009 08:47 PM
When I built my house I applied OSB sheeting to the frames before raising the wall.
So I had to allow for both the rim thickness plus the OSB thickness.
